Author [NL] [FR] [ES] [DE] [SE] [IT] Topic: Changing Parking Light Bulb  (Read 2174 times)
  • Offline Uczbpha
    • Tiger Member  ‐    67
    Offline Uczbpha
    • Bike/Model: 800XRX
    on: Nov 16, 2019, 09.12 pm
    Just doing a bit of pre-emtive investigation here, I have a 2015 XRX with a beak fitted, now to change the parking light bulb it looks like the beak needs to be removed, so to remove it do I need to remove all 6 bolts, 2 top, 2 side and 2 underneath and then slide the whole thing forward or is it just remove the 4 underneath so it drops down enough?  Iíve seen a couple of vids online but they are older models which are different?
    Thanks for any advice.
  • Offline tauzero   gb
    • Tiger Master  ‐    879
    • Bike/Model: Tiger 800 XRx
    Re: Changing Parking Light Bulb
    Reply #1 on: Nov 23, 2019, 02.18 pm
    I've got to do the same job myself, on an XRx that I fitted a beak to. You need to remove the entire cockpit assembly, not just the beak (that doesn't help, I tried it). Watch the first part of this, it'll show you exactly what to do:
    Last Edit: Nov 23, 2019, 02.20 pm by tauzero
  • Offline Uczbpha
    • Tiger Member  ‐    67
    • #2
    Offline Uczbpha
    Reply #2 on: Nov 23, 2019, 04.18 pm
    Thanks mate, thatís a big help 👍
  • Offline ferdens
    • Tiger Cub  ‐    8
      #3
    Offline ferdens
    • Put a Tiger in your tank.
    • Bike/Model: 17 Tiger 800 XRx
    Reply #3 on: Dec 21, 2019, 07.50 pm
    I've just changed the pilot/parking light for a Led. 4 screws. 5 minute job.
    Or am I missing something?
  • Offline kempy   gb
    • Tiger Master  ‐    556
      #4
    Offline kempy
    • Bike/Model: MK1 800XC 2010
    Reply #4 on: Dec 23, 2019, 11.28 am
    *Originally Posted by ferdens [+]
    I don't think you're missing anything bud, its a doddle 99% of the time apparently, but sometimes the bulb slips and falls into the headlight body which causes untold aggro and blue air
    It's a long way to the shop if you want a sausage roll
      #5
    Reply #5 on: Jan 03, 2020, 08.08 pm
    You haven't got a beak.
  • Offline scorpion68
    • Tiger Cub  ‐    1
      #6
    Offline scorpion68
    • Happy motor rider
    • Bike/Model: Tiger 800 XCx 15
    Reply #6 on: Dec 01, 2021, 07.41 pm
    Hi,
    I am new to this forum but I noticed it is a long search on finding how to replace that little bulb. I had to figure out that, after unscrew the 4 ones at the front cover, the transparent will not come off. So I made a little video on how to change the parking light. It is actually very simple. Just 4 screws out, take the ring off and peal the rubber holder out. Don't drop your bulb inside the headlight unit, or go fishing inside...
    We don't see the things as they are, we see them as we are.
