Rear Brake Disc & ABS Ring Bolts
(1/2) > >>
felix:
Changing my rear disc, note the comments on the torque specs sheet that the bolts for the disc & abs ring should be replaced ?
1 set at Fowlers is 32.88, or World OF triumph 49.32 ! (4 of each)
I can see sets of SS bolts on ebay for the disc at 12.00 for 4 (which is almost palatable !), but not for the abs ring..
Anyhow..... question is do i REALLY have to replace them ?
 :084:
KildareMan:
 :084:
Maybe not so much the abs ring but
Put it this way. The manufacturer recommends you do.
What are those bolts holding again?
Have a look also at https://www.squaredeals-ltd.co.uk/
CB250G5:
Harley do this as well.
Reason is that the new bolts have a dry Loctite type stuff on them, so new bolts get Loctited in.
I'd always reuse, but add a drop of Loctite to the old bolts.
Don't blame me if bits fall off though, if you're not confident, follow the manual.
felix:
Cheers for the comments chaps.....
I saw that the bolts come with Loctite already applied & assumed that's why "single use only" applies.... so as long as the bolts look ok and clean up etc i will re use them - with my trusty loctite of course....
BTW - if anyone is looking for a new rear disc then Demon Tweeks are selling EBC Rears with 20% off on ebay.
Use voucher code  PARTYTIME
So 81 reduced to 64.80 delivered.
This offer ends today tho !
 :002:
Bladerunner99:
 :002:
I have reused disc bolts before, just cleaned bolt and wheel threads and re applied threadlock, no issues at all.
