Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tiger Tool  (Read 1921 times)
Offline Tigger80
Tiger Tool
« on: December 23, 2019, 03:57:43 PM »
Good day guys!
Please help I am no expert in software and pc tactics but sure can understand basics.
So I have a Tiger 800 2012 model and downloaded the Tigertool V2.5 and have a ELM bluetooth interface but sure as hell can not get it to do the handshake with each other.My laptop has the follwing ports assigned or displayed as port 7 and port 8 whichever one I try it says cant connect with obd interface.Hence ignition on and kill switch off. :232:
Re: Tiger Tool
« Reply #1 on: December 23, 2019, 04:57:52 PM »
T800XC is the man to ask. TigerTool is his afterall. I would say though you could easily have a bad obd connector.
Lost again
Re: Tiger Tool
« Reply #2 on: December 23, 2019, 05:32:28 PM »
Have you paired the ELM to your laptop?
Offline Tigger80
Re: Tiger Tool
« Reply #3 on: December 23, 2019, 07:57:24 PM »
Rtwo yes it does connect to the laptop seems there is a comms fault but did test the elm 327 on my truck and it does work with torque pro app.
Re: Tiger Tool
« Reply #4 on: December 23, 2019, 08:26:50 PM »
I've never used it over BT so I'm shooting at stars here.
Try going into the Control Panel and then Devices and Printers
You should see it in there, right click it and if there's an option ..... 'Connect Using'
Select it and then 'Access Point'
Offline Tigger80
Re: Tiger Tool
« Reply #5 on: December 23, 2019, 08:46:40 PM »
Will give it a try thanx.
Offline Tigger80
Re: Tiger Tool
« Reply #6 on: January 06, 2020, 08:14:36 AM »
*Originally Posted by Tigger80 [+]
Ok so it seems that i have a interface issue and that the ELM 327 i have is a clone version of what I should have.Unfortunately you cant tell what you bought until you put it to work  :173:.So if someone can point me into the right direction of what to get or look out for so that I can get the right thing. Thanks.
Online T800XC
Re: Tiger Tool
« Reply #7 on: January 06, 2020, 01:36:56 PM »
...So if someone can point me into the right direction of what to get or look out for so that I can get the right thing. Thanks.
Although still a clone, the most reliable version I've found that's readily available (and currently the only one I tend to use & recommend) is the BBFLY BF32301. You should be able to pick these up from AliExpress (cheapest option), eBay or Amazon.
Online gordybrock
Re: Tiger Tool
« Reply #8 on: January 06, 2020, 03:41:40 PM »
  :460: :0461: I bought one from AliExpress...works flawlessly  :152:
I'm from Wigan Me
Offline Tigger80
Re: Tiger Tool
« Reply #9 on: January 07, 2020, 01:22:16 PM »
Thank you T800XC will see where I can source one ,it is already a step in the right direction.
