Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Engine management light😡  (Read 597 times)
Offline Xcxbadge
  • Get on with life
  • Bike: Tiger 800 xcx
« on: January 11, 2020, 01:09:58 PM »
I came back from a ride & put the bike on centre stand selected 2nd gear  to wax the chain which I have done many times before.
But the engine management light came on with codes of p0500 & 1521, which I believe is speed sensor & abs.
I tried this morning when bike is cold the 3 cycles of fan cutting in but has not put the light out.
Has this got to be done via laptop?.
Or has anyone near somerset got a dealer tool😁.
Re: Engine management light😡
« Reply #1 on: January 11, 2020, 01:28:32 PM »
So it's detected your rear wheel traveling much faster than the front. The fact it's not reset might indicate a buggered sensor?
Lost again
« Reply #2 on: January 11, 2020, 02:59:28 PM »
*Originally Posted by Xcxbadge [+]
You created the codes because (as KildareMan said) front wheel stationary, rear wheel revolving at speed (probably above 10MPH when ABS light normally goes out), creating imparity between front and rear ABS speed sensors.
It isn't 3 cycles of fan cutting in but 3 complete heat cycles .. go ride bike until normal temperature, park up and let engine go cold, then repeat twice more and MIL should go out. Or can be reset with simple use of Tigertool software and laptop.
Offline Xcxbadge
  • Get on with life
« Reply #3 on: January 11, 2020, 05:22:43 PM »
Stevie I got that wrong then, I will take it out which will be more fun.
« Reply #4 on: January 11, 2020, 05:57:34 PM »
Take a look here for info on what qualifies as a heat cycle....
https://www.tiger800.co.uk/index.php/topic,13212.msg163900.html#msg163900
Offline Xcxbadge
  • Get on with life
« Reply #5 on: January 11, 2020, 06:31:51 PM »
Quite confusing then 😂😂🤔
« Reply #6 on: January 11, 2020, 07:48:58 PM »
.... just ride as normal whenever you want and on 4th ride MIL should have reset and fault codes will eventually clear from memory (after 40 starts - from memory - if fault cleared). :306:
Offline Xcxbadge
  • Get on with life
« Reply #7 on: January 11, 2020, 08:51:04 PM »
Thank guys 👍
« Reply #8 on: January 12, 2020, 12:02:51 AM »
Download the .pdf in reply #1 which shows the fault codes, heat cycles required to clear MIL and clear cycles to erase fault code from ECU memory.  Worth keeping. :028:
https://www.tiger800.co.uk/index.php/topic,14493.msg176074.html#msg176074
Offline Xcxbadge
  • Get on with life
« Reply #9 on: January 12, 2020, 02:03:59 PM »
Went to go out this morning & when I started bike up the light had gone out.
Strange but took it out for a little run & all seems fine.
Thank for all your help.
