Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: New or used stepper motor  (Read 1325 times)
Offline littlej
  • Bike: Tiger 800ABS
« on: January 31, 2020, 04:57:14 PM »
I am heading towards replacing the dreaded stepper motor on my 62 plated 800ABS.
Ran great this morning, now it will not start or tick over unless I hold the revs up.
Should I go for a used stepper motor of bite the bullet and get a new one?
Also, am I going to have to fork out for one of these datatune  things?
I have a replacement starter motor from a 675 street triple which I plan to fit at the same time.
Re: New or used stepper motor
« Reply #1 on: January 31, 2020, 07:26:44 PM »
Try cleaning the linkage first.
Offline skidmark66
« Reply #2 on: January 31, 2020, 07:59:02 PM »
What is the problems with these stepper motors. I own a 14 abs roady and it runs just fine but should i be looking forward to it breaking down in the future with this problem or is it totally random.
Offline Abramsgunner
  • Bike: Tiger 800 XC ABS
« Reply #3 on: January 31, 2020, 09:58:58 PM »
*Originally Posted by littlej [+]
PO of my '14 replaced the stepper motor with a manual adjuster from another model Triumph.  I don't know the details but I'm sure Google does.....   :169:
'14 Tiger 800 XC ABS, '09 Kawasaki KLX331S
Offline grizzlybear
  • Bike: tiger 800Xr
« Reply #4 on: February 01, 2020, 05:52:43 PM »
It a minor problem, just clean the shaft, there loads of posts about this 'fault'here. The later models have a sealed stepper motor
Safe Riding
« Reply #5 on: February 01, 2020, 05:58:06 PM »
*Originally Posted by skidmark66 [+]
Not much IMO, it just needs maintenance
« Reply #6 on: February 01, 2020, 09:09:07 PM »
Even if you fit a manual adjuster in place of the stepper motor (Triumph don't sell manual adjuster any more btw but others will most likely fit) you still need to leave the stepper motor electrically connected otherwise you'll end up with MIL lit.
Offline skidmark66
« Reply #7 on: February 02, 2020, 09:43:18 PM »
Still none the wiser. What is it where do i find it what does it do. If its a common fault why no recall from Triumph?
« Reply #8 on: February 02, 2020, 10:21:37 PM »
It's the idle adjustment. The roller linkage can get gunned up. Clean it and all is good. There are no failures of the stepper motor that require a recall.
« Reply #9 on: February 03, 2020, 05:34:47 AM »
It's all here, right up there in the 'search' box  :016:
e.g.
https://www.tiger800.co.uk/index.php?topic=6806.0
