Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Oil leak near front sprocket  (Read 323 times)
Offline julianhj
  • Bike: 2013 Tiger 800
« on: February 06, 2020, 07:37:39 AM »
I've been noticing the odd drop of oil on the garage floor recently, and it's location suggested it might be chain lube, however a couple of days ago there was a more substantial amount, and it was clearly engine oil. I removed the front sprocket cover and could see that along with a build up of chain wax (which I've been using over winter) there was clearly a build up of oil directly beneath the sprocket in the 'V' of the engine casing, with staining down from there towards the side stand switch. I topped up the oil at the weekend to the upper mark and yesterday the level was in the middle - I'd ridden about 50 miles in the interim.
Is this likely to be a failing/failed output shaft oil seal, or are there other possible areas it could be? I couldn't see any staining above the sprocket. The chain and sprockets were changed about 2000 miles ago, the bike is on about 22k miles.
If it is this seal, is it a relatively simple job to replace? I'd be getting a mechanic to do it.
Thanks in advance.
« Last Edit: February 06, 2020, 07:39:55 AM by julianhj »
Online grizzlybear
  • Bike: tiger 800Xr
Re: Oil leak near front sprocket
« Reply #1 on: February 06, 2020, 08:53:23 AM »
I believe you can prise the old seal out using a seal removing tool.
https://www.machinemart.co.uk/p/cht267-seal-puller-tool/
I not 100% sure, but I'm sure a member will clarify it :084:
Safe Riding
« Reply #2 on: February 06, 2020, 02:29:56 PM »
While in practice a good tool for the task the issue is accessibility, I think you would struggle to get that tool in and manoeuvre it. :084:
https://www.tiger800.co.uk/index.php/topic,22513.msg256342.html#msg256342
Offline julianhj
« Reply #3 on: February 07, 2020, 09:49:10 AM »
Thanks for the advice, Ive managed to find a mechanic with main dealer experience who is going to look at it for me.
