Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Lowering Foot Pegs  (Read 303 times)
Offline attacklibrarian
  • Attacklibrarian's Tiger
  • Bike: 800 XCx
Lowering Foot Pegs
« on: February 14, 2020, 03:13:44 PM »
Has anyone tried these lowering foot pegs?
https://www.ebay.com/itm/Front-40mm-Extension-Large-Touring-Foot-Pegs-For-Tiger-800-XC-XCX-XCA-2015-2018/383386812001?hash=item5943a27e61:m:mKuYi0enQYCFZgReBEtM73A
I know some more reputable brands make lowering pegs, but these are closer to my price range at the moment.
Offline 9w6vx
  • Bike: Tiger 800XR 2018
Re: Lowering Foot Pegs
« Reply #1 on: February 15, 2020, 03:45:45 AM »
 :493: :300: I am looking for the same too but found the branded pegs too prohibitive.
  • Bike: 800 XCx
« Reply #2 on: February 15, 2020, 08:39:10 PM »
*Originally Posted by 9w6vx [+]
If you find a good solution, let me know! I'll do the same. For now, I'm going to try an Air Hawk seat pad to see if some lift there helps with the stock foot peg position. I'll let you know how that goes...
« Reply #3 on: February 15, 2020, 10:08:22 PM »
SW motech do a nice set. Have them on the tiger for years now
Lost again
« Reply #4 on: February 16, 2020, 10:59:39 AM »
Same here and even on the high setting they are still slightly lower than the standard pegs but because they are thinner top to bottom you dont loose any ground clearance. They are so much more comfortable being wider as well.
« Reply #5 on: February 16, 2020, 11:02:17 AM »
*Originally Posted by attacklibrarian [+]
A correctly inflated Air Hawk does not add any height. If you have it inflated so that it is increasing the height you are sitting on air and you will feel like there is jelly between you and the bike. On an Air Hawk the bones in you backside should just be touching the seat proper the tiny amount of air fills in the gaps.
Offline Bikertone7
« Reply #6 on: February 16, 2020, 01:02:50 PM »
Just a note of caution before lowering the pegs (or altering the dogbones) if you ride with your toes down a bit you'll ground your boots easily on corners.
Other Bikes: 1968 Triumph TR6 650cc (american export model), 1991 Transalp XL600V (everyday runabout), 1979 Kawasaki KL250 Trail Bike project.
Offline 9w6vx
« Reply #7 on: February 16, 2020, 01:24:00 PM »
Sure and thanks.
 :300: :062:
