Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What grease to use on slider pins?  (Read 3287 times)
Offline Tallpaul
  • Bike: 800XR
Re: What grease to use on slider pins?
« Reply #20 on: February 25, 2020, 07:22:04 PM »
*Originally Posted by Tallpaul [+]
I have used Copaslip for many years with success. Other copper based greases are available!
EDIT: I miss read the original post, mistaking pad retainer pins with slider pins. My apologies.  :431:
Silicon grease on sliders, copaslip on pad retainers...... :420:
Offline nobsta
« Reply #21 on: February 25, 2020, 07:28:50 PM »
They're 2 pot and they do have slider pins.  :002:
« Reply #22 on: February 25, 2020, 07:59:40 PM »
*Originally Posted by nobsta [+]
Hi Nobsta, thanks for clearing that up.
Offline nobsta
« Reply #23 on: February 26, 2020, 09:40:46 PM »
 :152: :152:
Offline tigerman1960
  • Bike: tiger800 XCA
« Reply #24 on: March 09, 2020, 04:17:47 PM »
Well worth spending a few quid on line and buying stainless caliper pins, and a smear of copper type grease is all I have ever used on the pins with no I'll effects
Offline Djairouks
« Reply #25 on: March 10, 2020, 07:57:34 AM »
Came across this pretty interesting information, that remembering the days I worked in coating industry and material science tests, seems pretty legit even if it's to sell their product.
https://pagid.com/wp-content/uploads/2017/06/Copper-grease.pdf
Also don't know if the impact is so important in the real world, but as I understand it copper grease should not be used anywhere in calipers, because you do not want more heat transfer to the brake fluid, that loses efficiency after it gets too warm and spoil faster with more heat.
Offline Tallpaul
  • Bike: 800XR
« Reply #26 on: March 10, 2020, 09:13:58 AM »
Intersting read, thanks for posting.  :460:
Offline Bladerunner99
  • Bike: 2018 XCA
« Reply #27 on: March 10, 2020, 10:33:12 AM »
Very interesting indeed and not something I was aware of.  I have used copper grease on just about everything on every vehicle I have ever owned over the past 30+ years and I must say have never had any issues, even driving on salt laden roads in the UK.  However, I may now reconsider its use.
Thanks for sharing
Ride to work. Work to ride
« Reply #28 on: March 10, 2020, 11:08:08 AM »
Copper slip/grease does what it says on the tin, it's an anti-seize for threads, not a lubricant.
https://www.greasemonkeydirect.com/blogs/news/grease-guide-what-is-copper-grease-used-for
Offline Djairouks
« Reply #29 on: March 10, 2020, 11:16:47 AM »
Thanks for sharing
Well it's no life or death issue, I guess it would show after many years of using it, but nothing horrible is going to happen, as long as you're not putting so much that it drips on seals or discs.
