Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Wheel removal  (Read 972 times)
Offline Hen99
  • Bike: Tiger 800 xox
Wheel removal
« on: February 24, 2020, 03:55:41 PM »
Hi all. Picked up a big puncture at weekend. Good RAC man needed 4 plugs and half a tube of gunk to seal it. Got me home ok. Now question how easy is rear wheel removal on 16 plate xrx. I can do basics but have not removed wheel before. Other than photoing everything any obvious pitfalls .
« Last Edit: February 24, 2020, 03:57:51 PM by Hen99 »
Offline GeoffS
  • Bike: XC - Green/Black
Re: Wheel removal
« Reply #1 on: February 24, 2020, 07:36:37 PM »
Hi Hen
Check out Muddy Sumps video(s); everything is easy to follow and straightforward.
Geoff
Re: Wheel removal
« Reply #2 on: February 24, 2020, 07:48:55 PM »
:0461:
Offline GeoffS
Re: Wheel removal
« Reply #3 on: February 24, 2020, 08:25:47 PM »
Thanks Steve
When there is no light at the end of the tunnel, and all hope appears to be lost, do you throw in the towel and admit defeat......, NO...., watch a Muddy Sump video and all is well in the world.
Geoff
Re: Wheel removal
« Reply #4 on: February 24, 2020, 09:51:25 PM »
 :084: ... are you sure Geoff  :187: ... I personally found it to be 'when I saw light at the end of the tunnel it was just some b*stard with a torch bringing me more work.  :005: :492:
Offline Hen99
Re: Wheel removal
« Reply #5 on: March 02, 2020, 06:47:06 PM »
Hi All
Thanks for the link to video, wheel off , New Tye fitted , wheel refitted , took bike  for test ride and ...... ABS light stays on ...hmmmm I was vey careful not to snag it and it looks still in place , Will it reset after a longer ride ??? :084:
Hen
 :300:
Re: Wheel removal
« Reply #6 on: March 02, 2020, 07:30:26 PM »
When you removed the ABS sensor did you notice and take care of the shim under the sensor and replace it correctly or you will have upset the clearance to the sensor wheel. Common mistake is to fit the shim under the head of the fixing screw thinking it is a washer.
https://www.tiger800.co.uk/index.php/topic,27105.msg294930.html#msg294930
Offline Hen99
Re: Wheel removal
« Reply #7 on: March 02, 2020, 09:26:08 PM »
Hi Stevie
Ahh, I suppose its a bit late to notice that the 800 in the video does not have ABS!!!!! Like everything in life , Its always easy when you know what you are doing ---, I will have to have a look at the sensor and see how bad it is rubbing- The wheel does turn  , so may all is not lost  :003:
Offline Hen99
Re: Wheel removal
« Reply #8 on: March 03, 2020, 09:54:18 AM »
So .I do have a gap between wheel and sensor.I think I may invest in some feeler gauges.and recheck wheel alignment. I may have to invest in some new torque wrenches as well...who said home maintenance was cheep 😮
Offline steve@lincs
Re: Wheel removal
« Reply #9 on: March 03, 2020, 10:26:03 AM »
How was your rim after all the dealing gunk, I've heard lots of reports that garages don't like dealing with sealed in wheels, but never heard how it was overcome?!
