Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tiger 800 XCA tubeless conversion?  (Read 2351 times)
Re: Tiger 800 XCA tubeless conversion?
« Reply #10 on: March 10, 2020, 11:43:22 AM »
*Originally Posted by padderico [+]
Just wondering if anyone has performed this conversion themselves and what compounds/materials they have used with results?
Reading time :008: (search facility is your friend  :148: )   :002:
https://www.tiger800.co.uk/index.php/topic,24420.msg272520.html#msg272520
https://www.tiger800.co.uk/index.php/topic,26605.msg290348.html#msg290348
https://www.tiger800.co.uk/index.php/topic,25903.msg289277.html#msg289277
Offline padderico
  • Bike: Tiger 800 XCA 18
« Reply #11 on: March 10, 2020, 12:56:13 PM »
Offline ozrob
  • Bike: Triumph 800 XCA
« Reply #12 on: March 11, 2020, 04:02:41 AM »
*Originally Posted by Q [+]
the conversion was done by a local company here in Johannesburg who specializes in overland adventure tours - they use a compound which seals the inside of the rim and the spokes (not sure which type of compound however) - takes about 3-4 days to cure and dry and I've seen that it looks like a black elasticised material when dry
they previously did a conversion for me on the spoke wheels of a BMW R1200R Classic which I rode the pants off for about 3 years (incl track days) with the tubeless conversion and never had an issue apart from the occasional flat due to nails/screws/sharp objects from the road surface in the rear tyre
thus, I would definitely recommend a professional doing the tubeless conversion for you irrespective of the absence of an extra bead lip in the 21" front - neither my XCA front nor the BMW rims had such a lip and I never had any hassles or warnings that the rims are not suitable for tubeless conversion
I have done the same at home using sikaflex to sear the rear wheel spokes, I basically fill up the valley where the spoke nipple goes through the rim, works well, but it does make removing the tyre a little more difficult.
ADV has a write up on how it's done, https://advrider.com/f/threads/tiger-800xc-tubeless-converts.845718/
Much easier to put a string plug in a tyre to fix a puncture than remove a tube on the rear wheel, replacing a tube on the front is not so bad.
DO NOT DO THE FRONT RIM....is has no safety bead, and the tyre can and did come off for me resulting in a nasty crash....
Offline Djairouks
« Reply #13 on: March 11, 2020, 08:00:48 AM »
Can vouch for the bartubeless, many Africa twin owners used their product and all where pretty happy, if I remember well, later spoke adjustments caused no problems !
