Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2012 tiger 800xc gearbox issues - jerks on 1st gear  (Read 1103 times)
Offline jsarwar469
  • Bike: 2012 Triumph Tig
« on: March 23, 2020, 01:09:58 AM »
Hi all!  Have had my tiger 800xc for almost a year. Bought it used 20kish miles. Started to have issue recently. First gear jerks every now and then and at times  few times back to back while in 1st. The rest of the gears are perfectly fine. I quickly go to 2nd when I can to avoid hurting anything else. The jerk is pretty intense almost feels like the 1st gear inside the gearbox is chewed up. Have anyone else had this kind of issue ?
Thanks !!
Online Paulhere
Re: 2012 tiger 800xc gearbox issues - jerks on 1st gear
« Reply #1 on: March 23, 2020, 09:14:57 AM »
I'd check the chain first.
Offline fastcat
  • Bike: T800/STR675/D675
« Reply #2 on: March 23, 2020, 02:11:03 PM »
Yes, mine with 75k miles always starts doing that when it is in need of a service! Your valves need to be checked. Air cleaner needs to be clean. Stepper motor needs to be cleaned and lubed. All these jobs are fairly easy to do and all that information can be found on this forum.
Offline jsarwar469
« Reply #3 on: March 23, 2020, 03:56:32 PM »
Just weird that it only does it on 1st. The rest are fine.
Online Rtwo
« Reply #4 on: March 23, 2020, 05:03:15 PM »
what he said
Online K1W1
« Reply #5 on: March 23, 2020, 09:04:24 PM »
*Originally Posted by jsarwar469 [+]
It is the lowest ratio gear and the one that magnifies these type of issues because of its low ratio.
Offline jsarwar469
« Reply #6 on: March 23, 2020, 09:07:06 PM »
Copy. Are you referring to the possible bad chain?
Online K1W1
« Reply #7 on: March 23, 2020, 09:21:10 PM »
All misfires or badly adjusted chain or another mechanical issues will be magnified in first gear.
I do agree with the others though you need to start at the front of the bike and go around it and check all the likely causes, chain adjustment and wear, front and rear sprocket wear, air filter cleanliness, clutch operation, etc. then get to the mechanical things like the stepper motor operation.
« Reply #8 on: March 23, 2020, 09:49:55 PM »
Also worth a check of  the cush drive rubbers in the rear sprocket and the front/rear sprocket teeth as well as the lock nut&shaft  on the front sprocket.
« Last Edit: March 23, 2020, 10:01:39 PM by chuckxc »
Online K1W1
« Reply #9 on: March 23, 2020, 09:56:27 PM »
Also worth a check of  the cush drive rubbers in the rear sprocket.
Good point Chuck.
