Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2012 tiger 800xc gearbox issues - jerks on 1st gear  (Read 2474 times)
Offline jsarwar469
  • Bike: 2012 Triumph Tig
Re: 2012 tiger 800xc gearbox issues - jerks on 1st gear
« Reply #30 on: March 27, 2020, 11:44:04 PM »
Is anyone able to confirm if 124 link is an exact fit for the XC model with 16/50? Now I'm a bit concerned.
Online Guyver
« Reply #31 on: March 30, 2020, 08:10:40 AM »
https://www.ebay.co.uk/itm/193239531862
This is the one I bought. I didn't need it in the end so I've got it for when I do eventually change everything over. I did count the links on mine and it's the correct size for a 2012 XC.
Offline jsarwar469
« Reply #32 on: May 09, 2020, 04:48:59 AM »
Ok here is some progress I made -
Got the new sprockets front/back and chain installed.
A few questions -
 Now the washer for the front sprocket how do guys bend it back without damaging the rubber on the front sprocket?
And do the master link looks okay? See attached pics. It is slightly stiff compared to the rest of the chain but wouldn't say by much., But enough to notice.
https://ibb.co/BgYty45
https://ibb.co/zxnxMMK
https://ibb.co/hHc5GYx
https://ibb.co/d5ZMkYh
https://ibb.co/SQJCb52
https://ibb.co/2nMygPv
https://ibb.co/VStXDxm
Offline grizzlybear
  • Bike: tiger 800Xr
« Reply #33 on: May 09, 2020, 10:25:03 AM »
I use Screwdriver to bend the tab 👍
Safe Riding
Online Guyver
« Reply #34 on: May 09, 2020, 10:48:54 AM »
*Originally Posted by jsarwar469 [+]
A few questions -
« Reply #35 on: May 09, 2020, 12:31:27 PM »
*Originally Posted by grizzlybear [+]
I bend them slightly (taco style) before I put them on and then just use a punch to fold them over
« Reply #36 on: May 09, 2020, 05:30:44 PM »
...do the master link looks okay?
It is slightly stiff compared to the rest of the chain...enough to notice.
Looks like you over-did it.
If you could source another (exact same) master link? you could do it over and get it right.
(check as you go...)
Offline jsarwar469
« Reply #37 on: May 09, 2020, 05:42:48 PM »
I ordered another master link. Okay to ride in the meanwhile ?  Someone suggested to pry on the plates slightly to loosen up the master link.
Online Guyver
« Reply #38 on: May 09, 2020, 06:48:27 PM »
Good luck prising them back out.
Worst case is you'll chew up your O rings. But as you get new ones with the new master link it should be ok. Not like you're gonna ride 5000 miles in the time it takes to arrive.
« Reply #39 on: May 09, 2020, 07:14:18 PM »
I believe you're overthinking this. If as you state the master link is just a little tighter than the rest  then you're ok. :350:
