Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Not starting after chanigng plugs  (Read 804 times)
Offline littlej
  • Bike: Tiger 800ABS
« on: March 29, 2020, 04:12:24 PM »
I changed my plugs and air filter yesterday. On starting up the revs would shoot to about 2500 then drop to 1200. It would do this every time. I left the engine running for 15 mins and allowed to cool before each start.
This morning I chose to strip it all down again to see if I had missed anything. Hose from the airbox was off.
Rebuilt it and now it will not start. Turns over easily but not running.
What have I done wrong?
Re: Not starting after chanigng plugs
« Reply #1 on: March 29, 2020, 05:30:41 PM »
Are you sure the coils are in their correct places?
Offline Guyver
« Reply #2 on: March 29, 2020, 05:45:00 PM »
Double check the spark plug gap and also the coils are a nice snug fit.
Offline tigerman1960
  • Ride triumph, for the journey ahead
  • Bike: tiger800 XCA
« Reply #3 on: March 29, 2020, 06:31:55 PM »
have you got an engine management light lit up on the dashboard ? if so you probably have a plug off somewhere under or around the air box.
if you haven't got a engine management light showing, just make sure the kill switch is set in the run position, i know it sounds simple, but its easy to hit by accident.
you say it turns over, but wont fire, make sure all the coils are pressed well down on the plugs, and recheck every connection under the tank.
never ride faster than you can think
« Reply #4 on: March 29, 2020, 07:29:30 PM »
Likely an elec connection under tank.
Offline littlej
« Reply #5 on: March 29, 2020, 10:46:45 PM »
Thanks guys, Ill strip it all down again tomorrow and check it all
Offline dorsetboy
  • Bike: Tiger XRT
« Reply #6 on: April 01, 2020, 04:53:14 PM »
So what happened did you fix it?
Loose Lips Sink Ships
Offline littlej
« Reply #7 on: April 04, 2020, 07:06:16 PM »
Got back to this today. Stripped her down checked all the connections and fitted a starter motor from a 675 street triple.
Rebuilt her, double checking everything on the way.
Tank on, plastics on, ignition on, fired up first turn.
Massive difference in starter power.
Offline ColinXCX
  • Bike: 2017 Tiger XCX
« Reply #8 on: April 04, 2020, 10:07:19 PM »
 :493: :047:
Offline taff
  • Bike: Tiger XC
« Reply #9 on: April 05, 2020, 08:55:47 AM »
*Originally Posted by littlej [+]
I'm glad that your problem is fixed, but........
you said it was cranking fine in the original post so why did you go the [pretty significant cost and] trouble of changing the starter motor?
It sounds like a lot of work to fix what was probably a loose connection
