Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Coolant change  (Read 327 times)
Offline Nomad
  • Bike: Tiger XRx
Coolant change
« on: May 04, 2020, 11:12:00 AM »
HI
Just done a coolant change but I cant see any showing in the expansion reservoir. Its got almost two litres in and Ive brought it to temp and tipped the bike (2016 so no bleed valve) rad is full to the brim. Thoughts, suggestions?
Thanks in advance.
Cheers!
Offline philmcglass
  • Mine's a pint
  • Bike: Tiger XRX 2016
Re: Coolant change
« Reply #1 on: May 04, 2020, 12:38:51 PM »
Spec says 2.69 litres capacity.
Find the Line
Offline Nomad
  • Bike: Tiger XRx
Re: Coolant change
« Reply #2 on: May 04, 2020, 12:43:02 PM »
Yes I noticed that, although Muddy Sump vid says about two bottles (two litres)
Offline philmcglass
  • Mine's a pint
Re: Coolant change
« Reply #3 on: May 04, 2020, 12:48:22 PM »
Sounds like you need to add more.
Find the Line
Re: Coolant change
« Reply #4 on: May 04, 2020, 12:51:05 PM »
Wasnt Muddy Sumps bike in the video the earlier model with the smaller radiator?
Offline Nomad
  • Bike: Tiger XRx
Re: Coolant change
« Reply #5 on: May 04, 2020, 12:51:39 PM »
Thats my problem, how?
Offline philmcglass
  • Mine's a pint
Re: Coolant change
« Reply #6 on: May 04, 2020, 12:54:43 PM »
Can you not add it into the reservoir?
Find the Line
Re: Coolant change
« Reply #7 on: May 04, 2020, 12:56:53 PM »
*Originally Posted by Nomad [+]
How to add more fluid? Let the bike cool, stand it upright (main stand if you have one) and tip fluid into the coolant overflow tank on the right side of the fairing until it is above the minimum mark. I use a long funnel and only tip a little in at a time to stop spillages.
Offline Nomad
  • Bike: Tiger XRx
Re: Coolant change
« Reply #8 on: May 04, 2020, 01:34:49 PM »
Ah smaller rad. Will try that K1W1, thanks.
Re: Coolant change
« Reply #9 on: May 04, 2020, 01:38:54 PM »
From memory the 15-19 models had a radiator that was about 15% larger than the 2010-2014 models. That was one of the big improvements in the 15 model when it was released along with better air flow to keep hot air more away from the rider.
