Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Bike stuttering as if out of fuel, but at least half a tank? Then cuts out  (Read 4770 times)
Offline tigerman1960
  • Ride triumph, for the journey ahead
  • Bike: tiger800 XCA
It's good to be part of a family  :417: :417: glad its sorted, at last  :062:
never ride faster than you can think
Offline Ace23
like to mention when you guys talk about changing the air filter you should always take off the whole bottom of the airbox as well, at the rear underneath that box is an air breather pipe from the crankcase I can guarantee you there will be a white creamy sludge in the tube if this is not cleared it will lead to crankcase pressure and the engine will stop running.
Offline stumble
When I watched muddy sumps video, he made a point of cleaning that tube, so I did the same. Good tip !
Its better to have a stumble than a fall!!
Offline stumble
 :187: OK, on the way home, I had the exact same symptoms as before. I've got a new battery and new plugs. So it can't be those. I've had a look on the forum for anything else even nearly like my symptoms, and saw mention of checking the coils. So that's what I have done and my results in ohms are;
Across the terminals 01.9 for each.
Terminal to post (inside) 11.54.
Do these figures look odd to anyone?
Any help appreciated, else I'll have to take the bike to Triumph.
 :161:
I'm a bit late to throw in a possible cause here but I've seen similar issues with a partially blocked fuel filter.
Not easy to get to and test on the Tiger
Offline stumble
Well, I did think of that awhile back, but had no issues for over a week. Just seems a bit odd....
Offline T800XC
*Originally Posted by stumble [+]
...saw mention of checking the coils. So that's what I have done and my results in ohms are;
Service manual pinpoint test indicates 0.8Ω - 1.2Ω so depending on the accuracy of your meter (and lead resistance) they might just about seem right.
Offline stumble
Apologies,  I should add that the resistance on just the meter is 01.5 ohms..... :110:
Offline Guyver
Double check your plugs are still tightened to the correct Torque settings.
Offline stumble
*Originally Posted by Guyver [+]
12Nm, will do when I get off shift.
