Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Pannier rails modification  (Read 359 times)
Offline Rgh999
« on: May 07, 2020, 07:29:20 AM »
Has anyone tried fitting a non triumph pannier to the triumph rails. I m wondering if the upper and lower plastic fitments  on the triumph rails are removable thus making the rails a bare loop on to which I could fit a Touratech pannier.  If so what is the diameter of the tube as I need an 18mm tube to accept the zega pro boxes. Also what are the measurements of the loop. Im looking for 350 mm x 245mm external on the frame. Thanks
« Last Edit: May 07, 2020, 07:31:27 AM by Rgh999 »
Re: Pannier rails modification
« Reply #1 on: May 07, 2020, 12:22:35 PM »
Hi, here is a guide, but the width and height are approximate as the bike isn't very accessible for getting camera in-line with tape measure and bike is on centre stand and chained down.
Tubing - 18mm
Width - about 345mm/350mm
Depth - about 230mm
Offline Rgh999
« Reply #2 on: May 07, 2020, 03:04:48 PM »
Stevie p many thanks. Width and tube size would be ok but depth is not suitable. Saved me splashing out on a pair on the off chance. Thanks
« Reply #3 on: May 07, 2020, 04:21:03 PM »
If you're not in a rush I could did out my big sash clamps in a day or two and try to get more accurate measurements.  :027:
Offline Rgh999
« Reply #4 on: May 07, 2020, 06:45:35 PM »
Thanks for the offer mate but I think its too big a difference. I think Ill just try to find a fabricator who can play around and re weld my SS Touratech pannier rails. The basics are there and the hoop will be right. Thanks anyway
