Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: XCa Won't Start on a Closed Throttle  (Read 241 times)
Online Rtwo
« on: May 13, 2020, 04:10:23 PM »
Anyone had this?
2016 XCa, just put it back together after a service and the only way to get it to start is with some throttle. Once running it's fine.
Sort of points to whatever they call the electronic version of the stepper motor but I can't see what's changed to cause the issue
any ideas?
Online T800XC
Re: XCa Won't Start on a Closed Throttle
« Reply #1 on: May 13, 2020, 04:26:43 PM »
Maybe the throttle position sensor?
A similar thing used to happen on the early Mk1s.
« Reply #2 on: May 13, 2020, 11:10:00 PM »
Very common mistake.  :138:...forget to connect the MAP tube onto the sensor near the front of the airbox. That would cause those symptoms. Worth a check but you'll have to raise the tank to see.
Online Rtwo
« Reply #3 on: May 14, 2020, 09:08:41 AM »
Thanks guys
It's now OK following a disassemble/reassemble of the rats nest of cables and pipes etc. under the tank.
Everything double checked and cleaned.
So I guess it was finger trouble somewhere  :034:
