Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: switched live for sat nav  (Read 201 times)
Offline ped
  • Bike: tiger 800
« on: May 23, 2020, 08:40:26 PM »
what are you people useing for a switched live on the later 2018 -2019 tigers :183:
Re: switched live for sat nav
« Reply #1 on: May 23, 2020, 09:19:25 PM »
Take a read through a previous solution for the gen 3 bike and see if it's a suitable solution (the white connector) for you.
https://www.tiger800.co.uk/index.php/topic,24111.0.html
Offline Northern
  • Bike: 800 XCa
« Reply #2 on: May 24, 2020, 10:44:49 PM »
So, I just had same question few moths ago.
Wanted to tap in to the horn cable, but on gen3 it will not work, cause they change wiring.
I really did not want to route cables under the tank, so looking close to electric schema from Hynes manual, I find out, there is switched +12 in the LED headlight. My Zumo consumes not more then 1A, so I desided it would be safe to tap in there.
Green is switched +12 and black is ground. Ground could be taken from the frame, but I decide to tap in.
For connector, I used waterproof contact pair from Aliexpress (I have ZUMO 595 and Montana 680, and I wanted to have possibility to use different from time to time).
But, for now, it seems to me, it would be better, if I would go with not switched but constant power. Most likely will redo my wiring, when I'll have time and wish :)
« Last Edit: May 24, 2020, 10:47:39 PM by Northern »
