More detail please. Which sensors and can I have a go please please please?
So far I've tested the idea with Erisin ES331 sensors intended for car use. Other similarr types should work such as the Xtrons TPMS07. The system is supplied with 4 sensors so I guess you have 2 spares!
I plan to build a small interface module that can be used with the sensors. This would allow the system to be used on any Triumph that has CAN bus and supports TPMS.
I'm looking at the design and trying to keep the cost minimal. It'll need a low current switched 12V supply and 2 wires to connect to the CAN bus. Ideally this would be the white connector under the seat on the latest models that's reserved for the Triumph Bluetooth module, but the diagnostic socket also has the CAN bus pins, but sadly only a permanent 12V output.
