Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Whats best lube for gearchange linkage?  (Read 455 times)
Offline posty
  • Posty
  • Bike: Tiger 800 XRX 16
« on: June 09, 2020, 06:09:52 PM »
Hi all
I just replaced my gear linkages with bolt-on items from E bay - https://www.ebay.co.uk/itm/Motorcycle-Gear-Linkage-Rod-Ball-Socket-Joint-10mm-1-x-RH-1-x-LH-Thread-M6/252898244563?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649.
Together with adding a shim washer to the gear lever to eliminate side play, this has transformed the gear shift - no play and very positive action.
Anyway, I just wondered whats best thing to lube the linkages and keep them in good condition - would have thought any kind of grease would just attract dirt and accelerate wear??
Any ideas please?
PS trying PTFE spray at the moment
Offline Bladerunner99
  • Bike: 2018 XCA
Re: Whats best lube for gearchange linkage?
« Reply #1 on: June 10, 2020, 01:41:27 PM »
I packed my OEM ones with red rubber grease because they have rubber boots over the joint, works well!
Ride to work. Work to ride
Online Rtwo
« Reply #2 on: June 10, 2020, 02:33:05 PM »
For that sort of thing, I tend to use a general purpose spray grease so that it's able to penetrate thoroughly
Offline posty
  • Posty
« Reply #3 on: June 10, 2020, 02:53:38 PM »
Thanks for the replies but thats my point - doesnt grease attract dirt and dust even though its covered by a rubber boot?
This will then accelerate wear
Online Rtwo
« Reply #4 on: June 10, 2020, 03:03:13 PM »
Can't say I've ever noticed it on any bike I've had.
Besides, I'm not entirely sure how it could attract dirt
  • Bike: 2018 XCA
« Reply #5 on: June 11, 2020, 01:56:00 PM »
Mine is ridden mostly off road in extremely dusty conditions, seems ok.
Offline Newhorizons
  • Bike: 2015XC
« Reply #6 on: July 02, 2020, 12:19:51 PM »
I used name brand chain lube, gets right into the rose joint and sets pretty dry.
Its probably going to wash out over a period of time but when I do sprocket change or service I will give it another spray.
I don't think that its going to be any worse than grease and you know its getting right inside
« Reply #7 on: July 02, 2020, 01:38:19 PM »
That should be ideal, being compatible with the O/X ring seals in our chains.
