Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: ECU  (Read 475 times)
Offline Seanocaoimh
ECU
« on: June 18, 2020, 10:23:34 PM »
Hi all,  I've just got tune ecu for android to enable me to adjust the idle speed.
 Now I've just been told you cannot change the idle speed with the android version, is this information correct.
Re: ECU
« Reply #1 on: June 19, 2020, 12:07:31 AM »
Have you tried the Windows version? From memory, I think that will do it.
Re: ECU
« Reply #2 on: June 19, 2020, 09:15:08 AM »
I might be mixing things up but I use both USB and bluetooth to connect tuneecu (not at the same time) with the android version. Am pretty sure Android via USB on the 11-14 Tiger will do the trick for you. You might need an OTG adaptor (I do)
Smartphone or Tablet Android version 4.0 minimum, dual Core 1.2 Ghz mini and OTG.
 You can test your phone or Tablet for OTG connectivity with the App "USB Host Test"
 and / or the App "OTG Troubleshooter" from Google Play Store.
Cable USB OBD2 KKL FTDI (The cable is the same as the windows version)
Adapter USB/micro (cable OTG) if needed.
Optional: Interface Bluetooth ELM327, version 1.4 or 1.5.
Attention: For the Triumph models, which can be reprogrammed via Bluetooth, special
Bluetooth- adapters like the "OBDLink LX" or the "OBDLink MX" or MX+ have to be
used, only these adapters allow the reprogramming of the compatible models (see Bike List).
Quote below refers to 11-14 only
Tiger 800, 800 XC  (up to 2014) -USB & Bluetooth*
* Read & Write ECUonly through USB
« Last Edit: June 19, 2020, 09:18:27 AM by KildareMan »
Offline Seanocaoimh
Re: ECU
« Reply #3 on: June 19, 2020, 04:58:55 PM »
Ok lads,
   I have all the relevant cables and connectors,
 will  have a go with the connection over the weekend and we'll soon find out if idle speed adjustment is available on the android version. ( fingers crossed).
                                  Thanks for the feedback.
