Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Issues after lying idle for a few months 2015 XRX  (Read 929 times)
Offline Wight Biker
  • Never too old to ride.....
  • Bike: Tiger 800 R
Re: Issues after lying idle for a few months 2015 XRX
« Reply #20 on: June 27, 2020, 08:31:09 PM »
Try and keep the bypass plug when they fit the new alarm. I had a weird electrical problem a year ago that seemed to be a possible alarm issue similar to you and as I had a bypass plug I was able to disconnect the alarm to check if that was the problem. (The alarm had been replaced under recall a year or so earlier) It wasn't the cause of the problem but at least I knew to look elsewhere! As it turned out, it was the 6 year old battery intermittently breaking down.
Offline peterdallan
« Reply #21 on: June 27, 2020, 08:33:43 PM »
I will let you know...........
« Reply #22 on: June 28, 2020, 12:13:10 PM »
If you don't have the manual for the alarm, you can find it at https://www.datatool.co.uk/faq-s4-green/ (green and red alarms are the same from the user point of view). It's worth putting in a PIN code just in case your keyfob battery dies.
