Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: How to switch off cruise control?  (Read 1451 times)
0 Members and 5 Guests are viewing this topic.
Offline HansTiger800
  • Dutch Biker
  • Bike: 800 XRX white
« on: July 01, 2020, 11:19:13 AM »
Hiya,
Pleased with my Tiger 800 xrx 2019!  One annoying issue, how to 'switch-off' the cruise control?
- braking ; nah  stupid way to do that, i do not want to brake riding at nice cruising speed
- use the clutch ; more stupid way of this issue....
- rotate gas to 'zero' ; ever tried this??  not a comfy way of disabling cruise control
Why does Triumph not has a push button (like all cars have) do to this ??
What i do now is ; a) rotate gas handle to the point where the bike wants to accelerate b) tap my foot brake shortly
How do other riders do this ?
cheers
Hans
Before on a GS550, GS750, GS1000, ST100 (x2), ST1300. Now on a TIGER 800 XRX
cheers
JJB
Offline fac191
  • Bike: Super Tenere ES
Re: How to switch off cruise control?
« Reply #1 on: July 01, 2020, 11:30:50 AM »
I use the clutch on my Tenere as its the smoothest way to disengage the CC.
Offline Djairouks
« Reply #2 on: July 01, 2020, 12:09:47 PM »
A slight push on the rear brake will do the trick, but I'm using the forward throttle all the time, because
most of the time I'm going to be braking after that anyway.
Offline Matchbox
  • Bike: Tiger 900 GT Low
« Reply #3 on: July 01, 2020, 12:39:41 PM »
Same here, dab rear brake and try to match throttle position to speed - unless Im slowing.
Find it of limited use on a bike since bikes need more input than cars. Mainly used when right hand needs a rest.
Offline FROGY46
  • quo vadis
  • Bike: Tiger 2019 XRT
« Reply #4 on: July 01, 2020, 12:53:14 PM »
 Page 97 of the owner's handbook .french edition!!! simple turn the throttle opposite way 2.3 millimeter. :087:
Be thought of as an idiot in the eyes of an imbecile is a sensual delight of fine gourmet
Offline rubbertoe
  • Bike: tiger 800 xca
« Reply #5 on: July 01, 2020, 01:57:15 PM »
I either shut the throttle slightly or use the rear brake, sometimes the front brake. None of these methods bother me. I find it amazing that my bike even has cruise control. I do not use cruise control much though as I find it kind of scary like it is tempting to lose focus on impending dangers, same as I would not want to listen to music in my helmet while cruising down the road towards certain death!  I am one of those riders who still has chicken strips on his tires.
Offline fac191
« Reply #6 on: July 01, 2020, 03:34:31 PM »
Thing is if you use the brake you are telling traffic around you that you are slowing down which may not be the case. Clutch method on my bike works with a little pressure so doesnt affect anything. Each to their own though.
Offline Djairouks
« Reply #7 on: July 01, 2020, 04:04:12 PM »
Yes but I don't see the harm, people behind should be paying attention, on my XRT the clutch method is far too abrupt I prefer not to use it.
Offline JW
« Reply #8 on: July 01, 2020, 04:26:53 PM »
That is how I do it - I think :-)
With the throttle in the rest position, you can "close" it further against a spring stop and it disengages cruise control.  2.3mm?  Maybe 2.3 degrees.....
Online Snownorge
  • Bike: Tiger 800 xrx
« Reply #9 on: July 01, 2020, 05:33:03 PM »
I just gently close the throttle usually,or just press the arm/disarm switch on my 2015,does  2019 bikes not have the arm button ?
« Last Edit: July 01, 2020, 05:38:01 PM by Snownorge »
