Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: US made stainless steel engine bars for tiger 800.  (Read 1101 times)
Offline ccmp
  • Bike: 2015 800 xca
« on: July 08, 2020, 10:31:03 PM »
US made stainless steel engine bars for tiger 800. 2015 on but i think they should fit the gen 1 model also. Regarded as the strongest bars 1 inch stainless with black coating photos to follow.
180
https://www.ebay.co.uk/itm/AltRider-Crash-Bars-for-the-Triumph-Tiger-800-2015-current/232997288255?hash=item363fb8793f:g:~fcAAOSwP8db5cAT
These one inch stainless steel AltRider crash bars for the Triumph Tiger 800 are cut on a 5 axis laser for strength and perfect fit.
100% made in the USA, these Tiger bars utilize the strongest mounting points the bike has to offer. Like all AltRider engineered crash bars, these will fit seamlessly without any grinding or bending on your part. Unlike other crash bars, we don't use flanges or weak tabs and are not hung, they're actually mounted.
One specific feature of these bars is the hidden connector in the front to yield a seamless system. In the case of a hard impact on one side, the energy will be transferred from one side to the other. The impact will be distributed to not just the one or two mounts but all of the mounting points, even on the other side of the impact.
   Compatible with all Tiger 800 Models
   Stainless construction fights corrosion and rust
   Hand TIG welded crash bars are 1 inch diameter for additional strength
   Manufactured in America
   All coping is cut on 5 axis laser then hand TIG welded
Offline geordielad
Re: US made stainless steel engine bars for tiger 800.
« Reply #1 on: July 09, 2020, 12:11:12 AM »
PM sent 👍
« Reply #2 on: July 09, 2020, 01:01:48 AM »
*Originally Posted by ccmp [+]
I am not sure whether the later bars fit the earlier bikes but the early bars do not fit the later bikes due to the changed plastic shrouds on the 15 and later bikes.
Offline ccmp
« Reply #3 on: July 09, 2020, 07:41:24 AM »
I,d say you are correct. They will fit the frame but they will foul the plastics.
Offline ccmp
« Reply #4 on: July 09, 2020, 07:43:51 AM »
Offline ccmp
« Reply #5 on: July 09, 2020, 07:45:24 AM »
Note that the paint in the background is unrelated. Bars are original and unmarked.
Offline ccmp
« Reply #6 on: September 12, 2020, 12:55:47 PM »
Bump, if any interested let me know.
