Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
March 08, 2021, 05:57:32 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Noisy clutch basket
Print
Pages:
1
2
Go Down
Author
Topic: Noisy clutch basket (Read 2356 times)
AvgBear
Tiger Jedi
Bike: '12 Venom Roadie
Re: Noisy clutch basket
Reply #10 on:
July 15, 2020, 05:52:29 PM »
The T800's Primary gear drive (from crankshaft to clutch) is a, normally somewhat noisey, straight-cut gear drive -- but, it is "spring-loaded" in order to keep it quiet.
The clutch basket, when engaged (h/bar lever released), is quiet b/c the clutch springs press everything together. The clutch plates can, however, rattle in the basket's grooves - if sufficiently worn? - when the clutch is released (h/bar lever pulled-in).
When the engine is running in neutral with clutch engaged the transmission's input shaft is turning. First gear's pinion is cut (affixed) to the input shaft and, so, is also turning. That 1st gear pinion is driving the 1st gear on the output shaft which is running free (since not engaged by a shift-fork) on a bushing on the output shaft. If that bushing is worn?, some noise may be produced.
Other gears may be turning - some on bushings - as well?
Another source (from the gearbox) could be due to the shifting drum not being fully "detented" and allowing shift-forks to be sliding components into improper locations? Fairly easy to check the shift-drum detent location.
Logged
AvgBear
Tiger Jedi
Reply #11 on:
July 15, 2020, 11:03:05 PM »
n.b. From the above ^^^: "when the clutch is released (h/bar lever pulled-in)" = clutch disengaged.
Logged
Alan215
Tiger Member
Bike: Triumph tiger
Reply #12 on:
July 16, 2020, 07:36:18 AM »
Ok when in neutral clutch leaver not pulled on the h/bar IT is noisy noticed low revs 2-3000 it seems gravely vibrations if u know what I mean
Logged
AvgBear
Tiger Jedi
Reply #13 on:
July 16, 2020, 11:00:15 PM »
Okay, clutch lever not pulled in (clutch engaged) means that the transmission's input shaft in the gearbox is turning along with a gear (or two? and a bushing or two?). The transmission's output shaft is not turning b/c neutral is selected (and it has the sprocket & chain).
The clutch is removed as a noise source b/c it is "engaged" (springs pushing all the parts together) and has no free, moving, parts inside.
This leaves transmission parts as the probable source of any noise?
Logged
Alan215
Tiger Member
Bike: Triumph tiger
Reply #14 on:
August 06, 2020, 05:52:51 PM »
Hello again I’ve had a garage check this out and he says it’s normal he started it up and revel it to about 3000 so was happy but now I’m finding when riding it at about the 3000 in 1st 2nd it sounds like a straight cut gear box u would have on a car so does this shed any light on what it could be or again am I paranoid
Logged
ozrob
Tiger Cub
Bike: Triumph 800 XCA
Reply #15 on:
December 04, 2020, 01:23:06 AM »
My 2018 XCA has the same issue, rumble in neutral clutch engaged, the noise goes away when clutch dis-engaged(lever pulled in) as some have said in neutral the only things spinning is the input shaft so it could be the input shaft outer bearing as I can also feel the rumble when riding at 4000RPM in all gears. My dealer has no idea and did say the noise is normal....or the clutch basket....not sure on how it can be the clutch basket as the friction and drive plates are compressed together by the springs so technically the inner and outer are one drive unit with no free play, the oil pump is driven from the outer basket, which is constantly in motion, as the inner basket stops spinning when the clutch is dis-engaged, and the transmission input shaft stops spinning.
The dealer even suggested in replacing the pressure plate bearing that is housed in the inner clutch basket....I checked the bearing and it spins freely....thus it has to be a bearing on the transmission input shaft. The bearing is retained on the shaft within a housing, according to the workshop manual the input shaft needs to be removed ( after splitting the engine case) and the bearing pressed off.
Big job for the average workshop.....thus the noise is normal....just because the noise is normal does not make it correct, as the noise was not there when the bike was brand new, and the noise appeared at around the 1000km mark, and now has 30,000km and the noise is louder.
Last Edit: December 04, 2020, 01:24:57 AM by ozrob
Logged
suffolktiger
Tiger Member
Bike: 18 Tiger XCA
Reply #16 on:
December 04, 2020, 06:02:47 PM »
Both my previous 765 street triple and now my tiger have done this from very early, regardless of oil change etc. I’ve ridden a few others and they were all the same, including the speed triple interestingly.
I don’t like it but it does appear to be ‘normal’
Logged
boldie
Tiger Member
Bike: 2020 Plate XRt
Reply #17 on:
December 04, 2020, 07:51:03 PM »
My 2020 plate XRT does this too, started at around 500 miles.
Not keen on it, but comforting to know it's "Normal".
Logged
chris_notts
Tiger Member
Bike: Tiger 800 ABS
Reply #18 on:
December 05, 2020, 05:24:23 PM »
Mine is 2014 and now has about 23K miles on it and its always had a rattle when in neutral, more or less from new. It still occasionally bugs me when I notice it, usually sitting at traffic lights and its a bit more noticeable if the engine is cold. It's been regularly serviced every 6K mmiles by a Triumph specialist the last twice at 12K and 18K miles.
He commented when he first serviced it at 12K that noisy rattly clutches are pretty regular on Tiger 800s and Street Triples and nothing to worry about. It disappears when the clutch is pulled in, so therefore guessing it might be rattly clutch plates or something like that. My view for what its worth is if a guy who makes his living servicing Triumphs, says nothing to worry about and doesnt try and sell me anything extra to "correct the rattle", I'll trsut what he's saying and not worry about it.
Logged
Print
Pages:
1
2
Go Up
Noisy clutch basket
More power for the 2018 tiger 800XCA
Newhorizons
Today
at 03:56:47 AM
Fork Oil renewal problems
AvgBear
Yesterday
at 11:13:16 PM
GoPro mount ideas
Sat Navs, Intercoms, Cameras, and other tech gadgets
Elmer J Fudd
Yesterday
at 08:42:23 PM
Genuine Triumph Adjustable Touring Screen - New & Unused - A9708399
For Sale
2wheelstony
Yesterday
at 07:51:17 PM
Rear Hugger wanted
Items "Wanted"
2wheelstony
Yesterday
at 07:44:05 PM
Happy new bike day
2wheelstony
Yesterday
at 07:42:41 PM
Tiger 900 rally pro settings
James13
Yesterday
at 07:41:49 PM
Hepco and Becker upper tank protection bars issue. Tiger 900
flyingburrito
Yesterday
at 07:03:05 PM
Tiger 900 Rally Pro - stock bar risers and flipping them 180 degrees
rainbow-walker
Yesterday
at 06:57:55 PM
Tiger 900 Rally Pro - Be careful with the OEM crash bars!!!
flyingburrito
Yesterday
at 06:56:01 PM
