Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Small oil drip from drain hose after oil change  (Read 691 times)
Offline Mav
  • Bike: 800 XRx
Re: Small oil drip from drain hose after oil change
« Reply #10 on: July 18, 2020, 10:13:31 AM »
I would take off the sprocket cover and have a look how much gunk is behind there and give it a good clean. Then see if your still getting the drips.
2017 XRx
« Reply #11 on: July 18, 2020, 11:43:36 AM »
 :0461: .... and also worth doing as there could simply be coincidence with the oil change and in fact be a totally separate issue like a starter leak from the gearbox sprocket. :027:
« Reply #12 on: July 18, 2020, 09:19:39 PM »
*Originally Posted by MarcW [+]
Could be the air box drain, oil from the crankcase breather if not a vapour will drain out.
AFAIK, there is no air-box drain?
