Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tiger 800 2011 to 2014 Wilbers Shock (AS NEW) ROADIE  (Read 606 times)
Offline Tedric
« on: July 17, 2020, 10:47:31 AM »
Wilbers adjustable rear shock for Triumph Tiger 800 (A08)  2011 - 2014. Road version.
As new, never been used on the road, it was fixed to motorcycle but found that it was too short for the XC version (which has spoked wheels and a 21 inch front wheel).
It has been set up at the factory for:
Rider weight 106 kg
Pillion weight 69 kg  at 25% of time.
Luggage weight 30 kg.
Spring rate is 120 N/mm at 185 mm long
Eye to eye center length is 345 mm.
Complete with Hydraulic preload adjuster and clamp.
Compression tank with mounting rubbers.
Manual and mounting instructions.
It has the original warranty card dated 14/12/18 but I do not think warranty is transferable.
With this shock the compression tank is connected to the shocks body by a flexible steel hose. Therefore it is an ideal alternative for road motorcycles with limited space. The hose can be placed individually where there is enough space for example on the rear frame where air flow can provide additional cooling. The adjustment screws for high- and low-speed compression, each tunable in 22 clicks, can be easily reached from the outside. Rebound can be modified by an open bleed system in 22 clicks and the preload is continuously adjustable.
This should also fit other Triumph Tiger 800 road versions, years 2015 on, its eye to eye length is 345mm, but please check.
PRICE 480.00   OR BEST OFFER                       PLUS 12 DELIVERY
Payment by either cash on collection from Chesterfield Derbyshire.  Or PAYPAL FRIENDS AND FAMILY.
« Last Edit: July 17, 2020, 11:10:14 AM by Tedric »
Offline fac191
  • Bike: Super Tenere ES
Re: Tiger 800 2011 to 2014 Wilbers Shock (AS NEW) ROADIE
« Reply #1 on: July 17, 2020, 03:58:30 PM »
Bargain cant believe someone hasn't picked this up.
Offline mcinlb
  • Bike: 2018 Tiger 800
« Reply #2 on: July 17, 2020, 05:04:43 PM »
Yes, should fit any T800, I swapped out a Maxton shock from a 2013 T800 to a 2018 model, fitted perfectly..
Offline ronaldo
  • Bike: tiger 800
« Reply #3 on: August 25, 2020, 12:32:21 PM »
Give me your best once in a lifetime price on this and and I might be able to see you right
Offline crispey
  • Bike: tiger 800 thrux
« Reply #4 on: August 29, 2020, 01:26:10 PM »
Pm sent
Offline Tedric
« Reply #5 on: August 29, 2020, 03:42:58 PM »
 Its now been sold.
