Author [NL] [FR] [ES] [DE] [SE] [IT] How To Use TigerTool V3.3 Service Utility Software  (Read 21191 times)
ANDREASRUDOLFOVO, TommyZ and 13 Guests are viewing this topic.
  • Offline Lukenrg   it
    • Tiger Cub  ‐    1
      #250
    Offline Lukenrg
    • Bike/Model: Tiger 800XRT
    • Country: it
    Re: How To Use TigerTool V3.3 Service Utility Software
    Reply #250 on: May 25, 2022, 07.19 pm
    Thanks a lot T800XC!!! I used a "bbfly OBD2, BF32301 USB" bougth on Amazon, i have a Tiger 800 xrt 2019 and the program V3.3 worked perfectly!
    Thanks again for your help, you are helping everyone everywhere. A big hug from Italy  :047:
  • Offline PixelZA   za
    • Tiger Cub  ‐    2
      #251
    Offline PixelZA
    • Bike/Model: Tiger 800 XCA
    • Country: za
    Reply #251 on: Jun 02, 2022, 05.41 pm
    Thank you very much for your effort in developing this  :763:
    I'm am however battling to get it to connect to my 2019 Tiger 800 XCA. I tried two different ELM 327 OBD scanners. I'm able to connect successfully using the TorqueOBD Lite app on my phone, and it can access the ECU, but TigerTool just keeps saying "ECU Read Error" right after the "ECU Handshake" message. Do you perhaps have any advice?
  • Online T800XC   ua
    • Tiger Jedi  ‐    2698
    • #252
    Online T800XC
    • Bike/Model: Tiger 1200 XRT
    • Country: ua
    Reply #252 on: Jun 02, 2022, 06.03 pm
    Are you using a Bluetooth ELM327 interface? These can be more problematic than USB-based devices as they can take longer to respond.
    The error message you've listed is TigerTool saying the ECU took too long to reply to a specific information request, so it bailed out. I allow 3 seconds for the reply but in reality in normal circumstances it should take far less time than this.
    • Tiger Cub  ‐    2
      #253
    Offline PixelZA
    • Country: za
    Reply #253 on: Jun 02, 2022, 06.43 pm
    Ahh, yes, unfortunately I'm using a Bluetooth device, it was all that I was able to get hold of  :003:
    The first device, a Kingbolen ELM327 did not connect at all, it just said it cannot find the OBD interface. So I bought a second adapter, some generic ELM327 (a little blue one) which at least finds the interface but sounds like it might not be fast enough  :110:
    I don't suppose there is a way to run the program with some argument that allows it to wait a bit longer for the ECU? I'm sorry for the trouble... I'll keep looking for a USB device in the meantime  :002:
    Last Edit: Jun 02, 2022, 06.45 pm by PixelZA
  • Offline TXC800   us
    • Tiger Cub  ‐    5
      #254
    Offline TXC800
    • Bike/Model: 2016 800XC
    • Country: us
    Reply #254 on: Jun 17, 2022, 08.14 pm
    Thank you for the Tool.
    What else do I need to get to be able to connect to the 800?
    As you can tell, not very much of a genious when it gets to electronics...or anything else for that matter.
    Enjoying the riding though!!!! :031:
  • Offline Duduphil
    • Tiger Cub  ‐    3
      #255
    Offline Duduphil
    • Bike/Model: Tiger 900 rally
    Reply #255 on: Jun 17, 2022, 08.40 pm
    bbfly-BF32302 USB Modifiziert FTDI chip OBDII Elmconfig Forscan HS-CAN/MS-CAN kompatibel mit Ford und Mazda https://amzn.eu/d/1SeYZj9
    this is what i bought, it works great on my tiger 900 rally pro and even on my nissan x-trail car.
  • Offline TXC800   us
    • Tiger Cub  ‐    5
      #256
    Offline TXC800
    • Country: us
    Reply #256 on: Jun 17, 2022, 09.05 pm
     Thanks!
  • Offline Fazer   gb
    • Tiger Master  ‐    301
      #257
    Offline Fazer
    • Bike/Model: 2019 XRt
    Reply #257 on: Jun 18, 2022, 10.09 am
    Cheapest Bbfly 32301 is available on AliExpress:
    https://www.aliexpress.com/item/32790694240.html
  • Offline TXC800   us
    • Tiger Cub  ‐    5
      #258
    Offline TXC800
    • Country: us
    Reply #258 on: Jun 18, 2022, 12.51 pm
     :763:
  • Offline rainbow-walker   00
    • Tiger Member  ‐    78
      #259
    • Bike/Model: Tiger Rally Pro
    • Country: 00
    TIGERTOOL AND TPMS
    Reply #259 on: Jun 21, 2022, 05.38 pm
    Just another thank you, I've for the first time successfully used TigerTool to update the TPMS sensor ID's to my second set of 'off road' wheels with 50/50 tyres on.
     :763:
    I'm running a MAC with parallels emulation software to run windows inside it, and it all works perfectly.  :152:
    Biggest issue was getting the TPMS serial numbers off the new wheels as they helpfully put the sticker on the underside of the TPMS unit against the wheels (and the seller didnt have the codes from the service pack).
    RBW.
