Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Bluetooth intercom  (Read 827 times)
Online Rtwo
Re: Bluetooth intercom
« Reply #10 on: July 22, 2020, 06:24:05 AM »
*Originally Posted by coddy [+]
I'm thinking of getting a Bluetooth headset to negate the need to stop and talk to my mates when touring mostly. A couple of them already have Sena devices so would I be better getting a sena to aid rider to rider communication or do all makes link up together just as easily anyway?
Save yourself a load of pain and get a Sena
Online Rtwo
« Reply #11 on: July 22, 2020, 06:29:58 AM »
Given the OPs requirement for a basic setup with good audio, I'd be looking at something from the lower end of the Cardo range as they have a standard 3.5mm stereo jack for the speakers (the ones I've seen anyway)
This would give the opportunity to upgrade the speakers to something like the UClear digital pulse units if required.
Sena use a proprietary plug for theirs
Offline Q
  • Bike: 800 XCA
« Reply #12 on: July 22, 2020, 06:34:07 AM »
- see a recent comparison between the 2 pieces of kit
wish both these OEMs would make a headset with a universal ear/mic jack so that you can use whatever kit works best for you AND adopt a universal inter-connectivity standard so that different makes of headsets can link up via MESH or BT
Online Rtwo
« Reply #13 on: July 22, 2020, 06:36:46 AM »
*Originally Posted by Q [+]
His mates all have Sena, hence the recommendation to do the same, regardless of what comes out best in comparisons
« Reply #14 on: July 22, 2020, 07:57:51 AM »
Theoretically they should all communicate via Bluetooth but in practice there are combinations that don't like each other. That could be as simple as which firmware version a device is using causing the problem but you don't know until you try to connect two individual headsets together. If you have no preference and your mates have Senas then Sena would be the safest bet.
Offline Tallpaul
  • Bike: 800XR
« Reply #15 on: July 22, 2020, 08:26:57 AM »
I've been using a Sena smh5 for 8 years. No problems and very basic, simple model.
Offline Kennydies
  • Bike: Tracer 900 GT
« Reply #16 on: July 22, 2020, 03:58:31 PM »
I, my wife and 3 friend all use the cardo bold (mesh network)  Never had an issue and just works once the initial set up is done.
There is no substitute for buying something that meets all your requirements...
Offline Q
  • Bike: 800 XCA
« Reply #17 on: July 22, 2020, 04:17:05 PM »
*Originally Posted by Kennydies [+]
amen to that - I'm happy to pay a premium and expect the kit to work the way it's supposed to and not have me faffing around with pairing and settings all the time
that said, I've also been using an ancient Sena SMH5 for ever and it does what it is supposed to do without any hassles
