Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 800 XRt cranking issue  (Read 1291 times)
Offline Lt.Jaybo
  • Bike: 2017 800 XRt
« on: July 28, 2020, 09:14:55 PM »
I have a practically new 2017 800 XRt.  Had it less than a year and has around 900 miles on it.  I dont ride it enough, so I got it out last week for a quick jaunt.  Bike cranked on first try in under 1 second.  Rode about 20 miles just to blow the dust off.  It was hot.  Around 100 Fahrenheit (38celcius).  When i got home I parked the bike and switched it off so I could open the gate to my property.  When I remounted, it would not crank.  The motor turned over once, then nothing.  I tried again, and the same.  I walked up the driveway stripping gloves, jacket and helmet, thinking I was going to have to push the bike the last 200 meters.  When I got back to the bike, maybe 3 minutes later, I decided to try to crank it one more time. (Did I mention it was hot outside?) The Bike cranked like new!!!!  I rode it up the driveway, parked it and got off.  Then tried to crank it again.  Motor turned over once then nothing.  I let it sit for about 3 minutes, and it cranked like a new bike!!!  Cranks on first try every day this week, but I have not ridden it since.  Any ideas why it did that?  I checked battery connections, and they seemed tight.  Battery seems strong when I turn on fog lamps.......What should I check.
2017 Tiger 800 XRt
2018 Yamaha XT 250
2019 Yamaha XT 250
2010 Kawasaki Teryx 700
Offline chico
Re: 800 XRt cranking issue
« Reply #1 on: July 28, 2020, 09:21:24 PM »
First thing to check is the battery with a load tester to make sure the battery is fully charged. I'm sure others here will have other suggestions.
« Reply #2 on: July 28, 2020, 11:54:47 PM »
You will find plenty of reading material on this forum on the subject of starting problems when hot. Many times the cause has been worn/dirty brushes in the starter motor. But...you bike is too new for that. Like you, some riders have experienced a no-start in high temperatures. It seems to be a characteristic of the model. Another possible cause on new bikes is vapor lock when hot. But no one has found an accurate cause. It would be a good idea to put your battery on an overnight charge if it has been sitting. These hot starter motors need all the current you can muster.
Online Q
  • Bike: 800 XCA
« Reply #3 on: July 29, 2020, 06:06:36 AM »
did you let the bike run thru all the diagnostics after ignition on and before cranking?
that seems to have been the cause of my starting problems previously - which have not recurred since
« Reply #4 on: July 29, 2020, 08:16:36 AM »
*Originally Posted by Q [+]
Agree. If you don't let the little computer do its thing the bike gets all hissy about it and won't start.
Been there, done that more than once.
Offline Lt.Jaybo
« Reply #5 on: July 29, 2020, 05:08:00 PM »
Yup.  Always........
2017 Tiger 800 XRt
2018 Yamaha XT 250
2019 Yamaha XT 250
