Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TigerTool for OBD2 ELM327 Bluetooth  (Read 573 times)
Offline Dagwin86
  • Bike: TigerXRX 800
« on: August 05, 2020, 09:59:21 AM »
I would like to reset the service wrench on my Tiger XRX 800 (2018) and I've read a few threads about the TigerTool.
Where can I download this software? I've read threads that state "the download link is at the end of this post", but have not been able to find a link.
I have a OBD2 ELM327 Bluetooth adapter which works with Car scanner and EOBD Facile but would much prefer the added functionality that I've read about TigerTool.
Please advise.
Offline Q
  • Bike: 800 XCA
Re: TigerTool for OBD2 ELM327 Bluetooth
« Reply #1 on: August 05, 2020, 12:49:36 PM »
*Originally Posted by Dagwin86 [+]
Please advise.
Search is your friend but seeing as this is your first time, you get a hall pass this one time :-)
https://www.tiger800.co.uk/index.php/topic,28260.0.html
Offline Dagwin86
« Reply #2 on: August 07, 2020, 07:03:31 AM »
Thanks Tiger Pro.
I have downloaded V3.0 and found appropriate USB-Serial drivers.
It seems that my OBD2 ELM327 adapter is not compatible.
TigerTool finds it and attempts to initialise it, then reports that OBD interface is disconnected.
I only paid $18 for the OBD2 device so I think it must be a cheap clone. I will research for a genuine ELM327.
Offline Q
  • Bike: 800 XCA
« Reply #3 on: August 07, 2020, 07:14:33 AM »
yip - had the same problem with some cheap Chinese knock-offs - found the Foxwell ELM327 V1.5 Bluetooth unit eventually and that connected straight-away - bit more pricey than the others but well worth it as it seems to have decent internals
Offline Dagwin86
« Reply #4 on: August 09, 2020, 02:42:07 AM »
Thanks. I'll check it out.
