Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Givi Toolbox  (Read 684 times)
Offline Rick B
  • Bike: 2020 XRT
Givi Toolbox
« on: August 05, 2020, 04:39:17 PM »
How do,
Has anyone fitted a Givi toolbox on the Triumph Expedition rails and been able to fit anything of size in due to the pannier frame cross bar obstructing it. Ive modded mine slightly by adding longer m6 bolts with deeper washers so it sits further into the wheel but to get my Airman compressor in(which is why i got it) it has to be on the lowest point ,thus making it catch the chain guard when SWMBO is on the back even on full pree load.
I'll try and send a pic of the offending item when its stopped lagging it down
The Perfect Woman,
A deaf and dumb nymphomaniac that runs an off-licence!
Re: Givi Toolbox
« Reply #1 on: August 05, 2020, 05:30:34 PM »
Is this Youtube clip any help? :027:
Offline Rick B
  • Bike: 2020 XRT
Re: Givi Toolbox
« Reply #2 on: August 05, 2020, 05:37:11 PM »
Cheers Steve,,,
It pretty much the same as what im after as he's using a tool roll  but my hopes was just to get the compressor which is reasonably small and a puncture kit,but same as the vid ,that pesky  cross bar interferes
The Perfect Woman,
Online Rtwo
Re: Givi Toolbox
« Reply #3 on: August 05, 2020, 05:46:41 PM »
What size box do you need?
I'm currently working on a bracket to take a Nanuk 903 case on those pannier rails
Offline Rick B
  • Bike: 2020 XRT
Re: Givi Toolbox
« Reply #4 on: August 05, 2020, 05:50:55 PM »
Is basically some form of moving the box into the wheel without affecting the wheel or mudguard and giving enough room to bypass that cross rail,,
I'll put some pics up tomorrow
The Perfect Woman,
Offline Rick B
  • Bike: 2020 XRT
Re: Givi Toolbox
« Reply #5 on: August 06, 2020, 05:48:50 AM »
This is what Im up against,as you can see looking down the rear cross bar interferes with anything of reasonable size assessing the box.
The Perfect Woman,
Online Rtwo
Re: Givi Toolbox
« Reply #6 on: August 06, 2020, 08:49:29 AM »
You need a box that's accessible from the side
Online Rtwo
Re: Givi Toolbox
« Reply #7 on: August 06, 2020, 12:07:44 PM »
This is what I'm currently working on, still a very rough mock up but I'm about there with the positioning
Re: Givi Toolbox
« Reply #8 on: August 06, 2020, 01:28:30 PM »
Make your own. A bit of lateral thinking is all it takes
This cost me about Aud$35 (20) all up including the knock off Pelican case
Offline TheRedKing
  • Bike: Tiger 800 (MY14)
Re: Givi Toolbox
« Reply #9 on: August 06, 2020, 02:21:51 PM »
*Originally Posted by Rick B [+]
Hmm, not quite what you'd hope for I imagine..
Especially when pulling the trigger to spend some more for a ready-to-go factory solution.
I'd try to move the box either as much upwards/to the back or downwards/to the front (not focusing on the holder but just on the box).
See if there is sufficient room, then try to reposition the mounting plate or make an adapter plate to connect the S250 to the mounting plate..
I have ordered a set as well; but for the Givi PL6401 rack, not the triumph one, the connector bar should interfere a bit less with this one  :155:.
Good luck!
