Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Chain and sprocket time  (Read 910 times)
Offline englishrob
  • Bike: STR675 , CRF450
« on: August 07, 2020, 07:29:19 AM »
2011 XC - used 70% on road 30% sand/trail.... :465: its time to replace the original chain and sprockets - what is the optimal configuration that would drop the revs a little on the longer rides without compromising the off-road torque.....thanks
Offline crispey
  • Bike: tiger 800 thrux
Re: Chain and sprocket time
« Reply #1 on: August 07, 2020, 10:34:36 AM »
Have a look on  https://www.gearingcommander.com/ it might help you
Online Tallpaul
  • Bike: 800XR
« Reply #2 on: August 07, 2020, 11:18:17 AM »
First gear is quite high anyway and won't help you off road if you raise it.
« Reply #3 on: August 07, 2020, 12:10:01 PM »
Personally I'd leave well enough alone.
Offline taff
  • Bike: Tiger XC
« Reply #4 on: August 07, 2020, 03:40:47 PM »
*Originally Posted by englishrob [+]
I've gone +1 tooth on the front sprocket. Done about 50k miles in that configuration with no problem at all. It still accelerates like a scalded cat when you drop a couple of gears and nail it   :028:
« Reply #5 on: August 07, 2020, 11:20:25 PM »
Professional mechanical engineers  and highly experienced motorcycle test riders at the Triumph factory, after extensive track/road testing and analysis,  decided that the OEM sprocket selection was the optimum configuration for this model.  Unless you have a compelling reason to change it, and know better than them, I'd leave it as is and just enjoy the ride.
« Reply #6 on: August 08, 2020, 02:41:15 AM »
None.
Anything that drops the revs on the highway will make the tall first gear even taller and almost unusable off road.
Offline taff
  • Bike: Tiger XC
« Reply #7 on: August 08, 2020, 09:52:05 AM »
Professional mechanical engineers and highly experienced motorcycle test riders at the Triumph factory, after extensive track / road testing and analysis agreed on the compromise that we see on the production models. This includes engine power output, suspension set up and gear ratio.
This doesn't mean that the ratio is the best for all users as everyone uses their motorcycle differently, changing the front sprocket +/- 1 tooth makes a difference of about 4mph at 5k revs in 6th. You are not changing the world.
Offline taff
  • Bike: Tiger XC
« Reply #8 on: August 08, 2020, 09:54:05 AM »
None.
really?   :087:
 :492: :492: :492:
Offline NORTY
  • RiderCoach
  • Bike: 2012 800XC
« Reply #9 on: August 12, 2020, 05:09:39 PM »
OP~
With your "70/30" use, you might as well leave it stock.
If you were "99/1,"  then I might suggest +1 CS.
Conversely, if you were "1/99," I'd say "GET A HUSKY 701!"
MSF RIDERCOACH (RETIRED!) :)
