Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Center stand fitting tiger 800  (Read 1555 times)
Offline Alan215
  • Bike: Triumph tiger
« on: August 13, 2020, 12:04:14 PM »
Hello all I have received a Center stand (not from triumph) do u have to use holes that the side stand uses to fit the Center stand has anyone got a Visio or pictures of the fitting of said Center stand
Re: Center stand fitting tiger 800
« Reply #1 on: August 13, 2020, 12:13:23 PM »
Centre stand mountings are different to the side stand mounting. Aren't there any instructions with it? And who is the centre stand made by?
Offline casclay54
  • The Fast Show (life before P C went mad)
  • Bike: 17 tiger800 xrx
« Reply #2 on: August 13, 2020, 12:19:40 PM »
This should help you  :152:
2012 Triumph Tiger 800XC 800 Center Stand Installation, youtube
« Last Edit: August 13, 2020, 12:23:12 PM by casclay54 »
You ain't seen me, right.
Offline casclay54
« Reply #3 on: August 13, 2020, 12:43:00 PM »
If your side stand is resting bike too upright put a 5mm spacer and longer bolt on the lower sidestand bolt under the sidestand bracket to kick it out a bit thus giving the bike a better lean angle.
« Reply #4 on: August 13, 2020, 01:23:09 PM »
A9778062
triumphinstructions.com
Offline Alan215
« Reply #5 on: August 13, 2020, 02:35:11 PM »
Hello u say the fittings for side stand are different but looking forward the rear brake side there is a hole for said cs but gear leaver side there is not so have to use one hole side stand is bolted through
Offline casclay54
« Reply #6 on: August 13, 2020, 06:42:10 PM »
Feel sure that this youtube video will explain all that you need to know  :028:
Worth noting that Tiger XC & XR centre stands are different heights, you have to have the correct one.
« Last Edit: August 13, 2020, 06:57:08 PM by casclay54 »
Offline Alan215
« Reply #7 on: August 17, 2020, 10:45:22 AM »
Just an update on the Center stand I refused to pay the 197 triumph wanted and so brought one from Germany 86 came with 3 bolts and the springs was a bit concerned how it would fit but it was spot on and fitted like a glove the triumph one comes with loads of bolts and brackets but this was so simple it was unbelievable
Offline Mercman
  • Bike: Tiger 800 (2012)
« Reply #8 on: August 17, 2020, 01:31:02 PM »
Alan, can you tell us where it came from, I'm looking for a centre stand for my 2012 Tiger 800, but so far the cheapest one I've found is 149. The one you've found sounds like it's a bargain
Offline Alan215
« Reply #9 on: August 17, 2020, 01:52:05 PM »
Hello if u put in the search bar (google ) triumph tiger Center stand u will see one come up from motea.com 89.59 (hope Im allowed to put this on sorry if not)
