Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: XRX Fogs, help req'd  (Read 403 times)
Offline Chuckie
« on: August 21, 2020, 03:01:56 PM »
Hi, Thanks for the add. Hope there's a tiger guru out there to point me in the right direction. I have a 2018 XRX Low, my first Triumph & loving it. My Tiger had heated grips, therefore the fog light switch already present, I put genuine Triumph LED fogs on it today, just plug and go I was told. NOPE.. found the connectors, plugged them in ok but the didn't come on.. do I have to plug the bike in CanBUS to tell it they are there. have I missed something. The seller said the lights worked fine when they came off their bike. TIA
Offline T800XC
Re: XRX Fogs, help req'd
« Reply #1 on: August 21, 2020, 03:07:58 PM »
No need to program anything on the CAN bus. Did you download the instructions? Everything you need to know should be in there.
Offline Chuckie
« Reply #2 on: August 21, 2020, 03:11:44 PM »
Did it without instructions, just plugged the connectors together, ignition on lights on.. fog lights NOT on !!
Online characticus
  • Bike: 2018 XRx
« Reply #3 on: August 21, 2020, 04:07:45 PM »
Did you add the fog light relay?
Offline T800XC
« Reply #4 on: August 21, 2020, 04:36:19 PM »
*Originally Posted by Chuckie [+]
Go here and put in the part number for the fog light kit:-
https://www.triumphinstructions.com/
Offline Chuckie
« Reply #5 on: August 21, 2020, 05:37:19 PM »
didn't add a relay, didn't think I had to, I was told cos I had the switch already it was plug and play, I will check to the instructions to see if I need to add one, thanks guys, x
Offline JW
« Reply #6 on: August 21, 2020, 07:04:43 PM »
Sounds like my fit was the same as yours.
The switch was present, the wiring for the lights was there but the relay that runs the spots was not installed.
There is a blanked out slot under the seat beside the battery, right next to another relay of the same type, an OMRON G8VA-1A4T
2018 Tiger 800 XRx Blue
Offline Chuckie
« Reply #7 on: August 21, 2020, 07:11:02 PM »
Checked it out and yes. I have a blanked out relay slot, I have the part number, will purchase tomorrow and complete the circuit. Thanks everyone.
