Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 10% ethanol to be standard fuel next year DO NOT USE IT  (Read 2185 times)
Offline philmcglass
  • Mine's a pint
  • Bike: Tiger XRX 2016
Re: 10% ethanol to be standard fuel next year DO NOT USE IT
« Reply #20 on: October 21, 2020, 07:50:10 PM »
Thanks Worty.
I'll have a browse.
Find the Line
Offline blacktiger
  • Tiger800XC owner since June 6th 2011
  • Bike: Tiger800XC
« Reply #21 on: October 27, 2020, 05:59:55 PM »
What I experienced was a gradual expansion of the tank on my Tiger955i. The front mounting hole in the tank was slotted already to allow for heat expansion. Probably from about ten years ago I noticed that the slot wasn't long enough so that the holes didn't line up any more. So I had to file the front slot. It got to the stage where I got fed up with it that I sold it a couple of years ago, to let someone else have the problem.
I suppose it depends on the type of plastic used and I hope that manufacturers will use appropriate materials in future.
I have noticed that in the 800 handbook it says that the bike is good to use up to 25% Ethanol like wot they have in Brazil.
As for the rust problem....just goes to prove that you should use your bike all year round so that it's getting fresh fuel all the time.
Black '13 Tiger800XC. The other British Land Rover. 31000 miles and counting.
Previous Tigers were 2002 955i & 2011 800XC
Offline hawkbox
  • Bike: Tiger 800 ABS
« Reply #22 on: October 28, 2020, 06:21:50 PM »
*Originally Posted by Worty28 [+]
I use Sta-Bil here in Ontario.  been using it for a very long time in my bikes when I get them ready to sit for 6 months in the winter. and use it in the snowblower and lawnmower.  60ml goes into 20 litres.
Same, we use that in Alberta too.
Offline philmcglass
  • Mine's a pint
« Reply #23 on: October 28, 2020, 08:36:43 PM »
Got some Lucas 10314 Fuel Stabilizer from ebay seller.
Enough for two tanks.
Also found Lucas Oil 10576 Safe Guard Ethanol Fuel Treatment. 473ml will treat 80 gallons.
Had a chat with Lucas rep and he said this is suitable for overwinter storage. Much better value than the 10134 option.
Find the Line
