Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Recommended upgrades / mods?  (Read 1056 times)
Online Q
  • Bike: 800 XCA
Re: Recommended upgrades / mods?
« Reply #10 on: September 01, 2020, 12:00:02 PM »
Learn to clutchless change.  :300:
 :0461: - got the timing for both up and down sorted now and @ 27k kms the box is as smooth as can be - don't even wish for a quick shifter anymore
« Reply #11 on: September 01, 2020, 12:13:16 PM »
*Originally Posted by louballs [+]
What gps bracket do you have? How is it mounted above the screen?
Currently I use a Beeline mounted to a ram ball and a long ram arm, mounted to another ram ball bolted to the lower screen mount plate (drilled two holes)
Offline louballs
  • Bike: Tiger 900 GT
« Reply #12 on: September 01, 2020, 12:26:34 PM »
Thanks, I was trying to think of a way to have my phone mounted center without blocking the screen. Have a ram mount coming today.
Offline Anderson
  • Hi Everyone
  • Bike: 2018 XCX
« Reply #13 on: September 13, 2020, 05:09:46 AM »
Get yourself a Denali Sound Bomb horn, The stock horns are embarrassing
Riding again for the first time in 15years
Offline louballs
« Reply #14 on: September 13, 2020, 08:27:45 PM »
Yeah, I was considering that since the stock horn is basically non existent. Seems like a pretty straight forward install too and reasonably priced.
*Originally Posted by Anderson [+]
Offline Anderson
  • Hi Everyone
  • Bike: 2018 XCX
« Reply #15 on: September 13, 2020, 09:19:09 PM »
I mounted mine under the front fender in same position as the original. After some heavy off roading and bottoming out front suspension the horn broke.
I bought a new one the type that the compressor is separate to the horn and mounted it under the gas tank faring.
Offline louballs
« Reply #16 on: September 13, 2020, 09:28:48 PM »
Good tip! I saw they had two different models. Did you need to use their separate wiring harness too?
Online Jarse
  • Bike: Rally Pro
« Reply #17 on: September 14, 2020, 09:03:05 AM »
*Originally Posted by TIger Lad [+]
Not much about at moment, apart from the triumph accessories. I have fitted lower and upper crash bars, pannier rack and a sat nav bracket which is above the tft screen. The bike is already equipped with lots of toys.
Which sat nav mount did you go for?
