Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Chain Maintenance Question  (Read 1144 times)
Offline Flyingbanana
  • Bike: Tiger 800,SV1000
Re: Chain Maintenance Question
« Reply #10 on: September 30, 2020, 02:24:47 PM »
My 800 roadie has no centre stand so i fitted R&G bobbins(25 ish) & then fitted hooks(12ish) to a paddock stand that was no longer in use as those bikes are being lifted with an ABBA stand set up.
All works fine for
Offline hawkbox
  • Bike: Tiger 800 ABS
« Reply #11 on: September 30, 2020, 08:07:57 PM »
I've used the center stand and a paddock stand for doing the chain, either works fine.  I've never had much trouble with the center stand, you just have to lift with authoritah when you put it up on it.
Offline kempy
« Reply #12 on: October 06, 2020, 09:45:54 PM »
:028:  :492:  :492: brilliant! cheers, made my night  :031:  :492:
« Last Edit: October 06, 2020, 09:48:24 PM by kempy »
It's a long way to the shop if you want a sausage roll
Offline louballs
  • Bike: Tiger 900 GT
« Reply #13 on: October 06, 2020, 10:20:26 PM »
Well, I got the stand from Triumph and has the dealer install it because I need to get it off the ground to put it on. Dealer said it was machined wrong because one of the pin clips doesn't sit right and can pop off. They wire tied it on, but had me contact triumph to get it sorted out. Sent triumph all the info, photos, etc. They responded asking for photos and the vin l, which I already gave lol. Should be fun.
