Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Evotech SatNav mounts for Tiger 900 range  (Read 2558 times)
Offline Northern
  • Bike: 900 RP
Re: Evotech SatNav mounts for Tiger 900 range
« Reply #10 on: October 07, 2020, 10:53:59 AM »
*Originally Posted by loufy [+]
Can we have a photo or a video of the Emotec assembly
can we raise or lower the windshield without the GPS moving
Had same question after looking Evotech installation manual.
https://evotech-instructions.s3.eu-west-2.amazonaws.com/instructions/014566+014925+triumph+tiger+900+garmin+sat+nav+mount.pdf
Also, support confirmed me, it's fix position on Tiger 900.
  • Bike: 2020 Tiger 900GT
« Reply #11 on: October 07, 2020, 01:36:10 PM »
The Evotech mount supplies a cross piece that replaces the original bar for moving the screen, the original bar being removed to fit the new mount.
And as above the sat nav mount is anchored on a static fixing..
Offline fastnfat
  • Bike: Tiger 900 GT Pro
« Reply #12 on: October 10, 2020, 06:20:29 PM »
Hello from France,
 Thank you very much
Tiger 900 GT Pro
Ducati Monster 1100 EVO
« Reply #13 on: October 12, 2020, 03:53:17 PM »
Well, fitted the Evotech sat nav holder today and as sod's law would have it, one of the 2 small screws that hold the dash lower to the mount was very tight on trying to remove 1 screw snapped.
Now these must be made of cheese and the mount is only a cast aluminium threaded hole, but as the screw was so soft I was able to drill it out and there was still some thread to remount the unit.
The fitting of the sat nav is a bit fiddly but is well made and when finished seems to be a solid unit, still to be tested.
At present I've only supplied the sat nav from the local power outlet,  all be it permanently on, I just unplug it when not in use as leaving the mount powered might eventually use the battery down..
Offline rainbow-walker
  • Bike: Triumph Tiger
« Reply #14 on: October 12, 2020, 09:06:27 PM »
Finally got around to fitting mine this evening, a little bit fiddly but just took my time.
Very pleased with the results.  Not entirely sure if I will keep the Evotech bar as I tend to keep my screen in the high position and dont move it.
RBW
Offline qwerty677
  • Bike: XRT
« Reply #15 on: July 30, 2021, 04:40:12 PM »
Hi Guys - just to confirm that despite the website identifying suitable for the Rally Pro, this will also fit GT models?
Tiger XRT & Scrambler with Watsonian Sidecar & BMW R1200GS
Offline fastnfat
« Reply #16 on: July 31, 2021, 12:38:49 PM »
I have one fitted to the GTPRO. I have a friend who has also fitted one to a Rally Pro. One thing we have both found with using TomToms is that there is not a lot of room to slide the unit onto to the docking station when in Landscape, the trick is to slide it on in Portrait and then rotate it on the docking station. Recently I have changed the screen to a MRA screen so that particular issue has now gone away with more clearance that gives. Hope that helps
Tiger 900 GT Pro
Offline qwerty677
  • Bike: XRT
« Reply #17 on: July 31, 2021, 01:06:58 PM »
Many thanks Sir - I just need them to come back on stock now!
