Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Rear caliper- are ABS and non ABS interchangeable? 2013 XC with ABS  (Read 778 times)
Offline steve@lincs
Hello,  the pad pin on the rear caliper on my 2013XC has seized and so far I've not been able to remove it ( next stage of drilling it out risks damaging the body) so I'm looking at getting a used one.   Some are described ABS or non ABS and worse still no mention either way.
Triumph list different part numbers which suggests they are not interchangeable.
Any advice or guidance appreciated.
Re: Rear caliper- are ABS and non ABS interchangeable? 2013 XC with ABS
« Reply #1 on: October 05, 2020, 03:16:30 AM »
I don't know the answer to your question but I'm wondering if you tried applying heat to the pin and surrounds in order to extricate said pin or have a machine shop have a go at it?
Offline Aussie Tiger
« Reply #2 on: October 05, 2020, 04:35:35 AM »
You could check to see if they have the same pads - Im almost certain they do, and if not Im even more  certain they have the same shape backing plate, with the only difference being the grooves in the pad material or thickness.
That wont guarantee the caliper mounting holes are identical but Id be amazed if they were different if the pads are the same.
« Last Edit: October 05, 2020, 04:37:18 AM by Aussie Tiger »
« Reply #3 on: October 05, 2020, 07:33:00 AM »
I suspect the difference will just be a clip or something for the ABS sensor
Offline steve@lincs
« Reply #4 on: October 05, 2020, 09:31:30 AM »
Thanks for the responses.  Personally I'm pretty sure it'll be the same caliper unit, as I can't think how ABS affects build of it (ignoring pad thickness)
I've soaked the area in oil, WD40 etc overnight; impact driver on the hex bolt ( stopped short of rounding it off; I've sawn the pin off near the far end to confirm where it's seized and remove the pads; heater up carefully - it's still attached to pipe -  but it's now time to get serious!
« Reply #5 on: October 05, 2020, 09:33:39 AM »
The calipes are the same.
Offline Shergar
« Reply #6 on: October 05, 2020, 11:01:58 AM »
You could try an oversize Allen driver - you can get them in a size just over what the standard is so they need a little force to get them in and then are far less likely to round the mating faces on the pin / bolt.
I can't recall the size for sure - but if its 5mm then get a 5.5mm and try that after letting some penetrating fluid do its job overnight
« Reply #7 on: October 05, 2020, 11:36:51 AM »
Hammer in a slightly larger Torx. Usually works. The pin and the Torx bit will both be buggered but you'll have the pin out.
