Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Maintenance kit for 800  (Read 1887 times)
Offline samsgrandad
  • Bike: Tiger 800 roadie
Re: Maintenance kit for 800
« Reply #10 on: October 06, 2020, 01:07:27 PM »
If you intend to keep the Tiger for a long time rather than buying the service kit as a whole consider buying the individual items and using a K & N air filter and iridium plugs, they can be found on ebay for not much more than Triumph charge for the standard items.
« Reply #11 on: October 06, 2020, 04:52:48 PM »
*Originally Posted by samsgrandad [+]
If you intend to keep the Tiger for a long time you'll want the most & best air filtration you can provide. Sadly, K&N sell their product as a performance enhancer -- not necessarily a better filter. Follow the science with controlled pore size media like Triumph and others use.
Offline Arianta
  • Bike: 2012 Tiger 800
« Reply #12 on: October 06, 2020, 07:47:47 PM »
Thanks samsgrandad, but Father Christmas is bringing me a Triumph kit!
Over the winter I shall be giving the bike a thorough overhaul. The back wheel is out now so I'll be checking that and the swing arm and rear shock in the next few days.
I've been looking at Muddysump's videos and they are really good at showing how to do anything.
'38 Triumph 250 single, '55 Tiger cub, more BSA Bantams than you can shake a stick at. '53 BSA A10, '66 Dunstall Norton 750 Atlas, 40 year break, MT07, R3, 650 Burgman, Bonnie America 865, 700 Deauville, Tiger 800. Phew!
Offline Arianta
« Reply #13 on: October 06, 2020, 07:51:16 PM »
Also I'll be asking FC for a 1/4 drive torque wrench and a carb balancing thingummy. :001:
Online tauzero
« Reply #14 on: October 06, 2020, 08:08:06 PM »
*Originally Posted by Arianta [+]
Um. You do know that Tigers haven't used carbs since the original 900 steamer, don't you?  :001:
Offline samsgrandad
« Reply #15 on: October 06, 2020, 09:19:55 PM »
Great news about the Xmas pressie!! While the back wheel is out make sure that you take the chain adjuster bolts completely out of the swinging arm and make sure you liberally apply Copper ease to them and also change them for stainless ones. The original steel ones have a habit of seizing in the aluminium casting of the swinging arm. (I speak from bitter experience!!!)
Offline Arianta
« Reply #16 on: October 07, 2020, 02:42:08 PM »
Of course, but when you want to buy vacuum gauges for balancing the inlets for whatever engine they are all listed as Carb balancing.
Offline Arianta
« Reply #17 on: October 07, 2020, 02:43:45 PM »
Noted samsgrandad, and thanks for the tip.
Offline Shergar
« Reply #18 on: October 07, 2020, 06:31:22 PM »
Tigertool shows the balance for all 3 cylinders directly with no external gauge, much simpler and free courtesy of T800XC
Offline Arianta
« Reply #19 on: October 08, 2020, 07:12:06 PM »
Delving deeper into the mysterious workings I find that the Air Intake Duct and the connecting rubber to the Air Box are both missing.
Smacks of careless maintenance to me  :182:.
Also I've removed the valve cover in preparation to do the valve clearances and the engine oil stinks. Bad. :232:
