Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Throttle adjustment  (Read 772 times)
Offline Alan215
  • Bike: Triumph tiger
Throttle adjustment
« on: October 12, 2020, 11:01:58 AM »
Hello can the play in the throttle b adjusted from by the throttle grip itself as in the manual it says take the seat off tank off then adjust the ends of the cable there
Re: Throttle adjustment
« Reply #1 on: October 12, 2020, 12:28:42 PM »
Depends on the amount of slop. Only a small amount then several cm from the twist grip is a barrel adjuster in a rubber cover. Slide rubber cover off and adjust as required. If there's a lot of adjustment required then seat/tank/airbox off is the better option.
Offline chico
« Reply #2 on: October 12, 2020, 05:25:02 PM »
Wouldn't it depend on the vintage of the bike? The OP doesn't state the model year of his bike.
« Reply #3 on: October 12, 2020, 05:56:16 PM »
A look at his previous posts indicate a 'gen 1' 2014 so cable throttle I believe.  :084:
Offline chico
« Reply #4 on: October 12, 2020, 07:58:21 PM »
In that case KildareMan is correct. :028: Throttle grip slop can be adjusted at the upper cables.
Offline Alan215
« Reply #5 on: October 12, 2020, 08:09:39 PM »
Great thanks Ill look tomorrow its not a lot but bit to much for my liking
« Reply #6 on: October 13, 2020, 09:49:01 AM »
Good point.  If it's a ride by wire system then the slop can be taken out with aftermarket rings you put around the throttle stop in the twist grip. Same can be achieved with a small o-ring or tie wrap.
Offline Alan215
« Reply #7 on: October 13, 2020, 01:37:21 PM »
Ok on looking there is no bolts/thread adjustment throttle grip end so do I need to take the throttle grip off and do it from inside
Thanks again
« Reply #8 on: October 13, 2020, 03:32:27 PM »
*Originally Posted by Alan215 [+]
Thanks again
Barrel adjuster is several inches down the cable from the twist grip, not at the twist grip.
Offline Alan215
« Reply #9 on: October 13, 2020, 07:59:08 PM »
Ok great Ill have a look tomorrow
