Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Can other boxes fit rear top box plate? And how hot does exhaust get on bags?  (Read 231 times)
Offline Crunchbytes
  • Bike: Tiger 800XC 14
Hi All,
Numpty question time: My 2014 XC has an original Triumph carrier and top box.  If I wanted a larger (internal capacity), less rugged top box, are there any others that fit the same mount? (with option of a backrest to keep SWMBO comfortable and happy  :016: )
And... I don't have side pannier racks and have been thinking about options for chuck-over saddle bags - but worried that they'll melt on the exhaust.  Worrying unduly?  Or is there either a type of bag or other fix that would work?
The saddle bags would be for the very odd occasion I'd need the extra storage - maybe a few times/year, so looking for the easy to attach/remove option rather than permanent.
Cheers all! R
Offline Q
  • Bike: 800 XCA
methinks you would need to use racks to seperate any throw-over soft luggage from the exhaust
I use the Givi racks, the outer frames of which are easily removed when not in use - ATG soft luggage
*Originally Posted by Crunchbytes [+]
Which luggage range is the topbox  ... Triumph Explorer (plastic) or Triumph Expedition (aluminium)?
Offline Djairouks
*Originally Posted by Q [+]
Unless you have such system as the mosko mule, it's very sturdy and they give you a heat chield,
that comes in between the exhaust and the mosko.
Offline Crunchbytes
It's black plastic with aluminium inserts - not 100% aluminium.  So guessing Triump Explorer?
Offline Crunchbytes
Thanks for heads-up re: side racks/frames and the Mosko Mule bags - will investigate both.  Like the idea that the side-racks come off easily.  Also like the idea of bags with built in heat shield.
Thanks all!  Very useful.
 :002:
