Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Shimmy, Shimmy  (Read 453 times)
Offline Arianta
  • Bike: 2012 Tiger 800
Shimmy, Shimmy
« on: October 23, 2020, 10:10:25 AM »
I've just checked the valve clearances on the 800. I found it quite difficult. The specs are, as you know, Inlet 0.1mm to 0.2mm and exhaust 0.325mm to 0.375mm.
My measurements are - Cylinder 1 inlet 0.16 and 0.15. Cylinder 2 inlet 0.15 and 0.16. Cylinder 3 inlet 0.18 and 0.19. All in tolerance, but No3 is near top.
Cylinder 1 exhaust 0.30 and 0.28. Cylinder 2 exhaust 0.23 and 0.28. Cylinder 3 exhaust 0.23 and 0.23. All below tolerance.
Question - are the exhaust tolerances low enough that it indicates re-seating/grinding in is required? I hope not because I would rather not have to drop the lump and remove the head although I will if necessary.
Question 2 - Are shims only available from a dealer?
'38 Triumph 250 single, '55 Tiger cub, more BSA Bantams than you can shake a stick at. '53 BSA A10, '66 Dunstall Norton 750 Atlas, 40 year break, MT07, R3, 650 Burgman, Bonnie America 865, 700 Deauville, Tiger 800. Phew!
Re: Shimmy, Shimmy
« Reply #1 on: October 23, 2020, 11:49:20 AM »
They haven't closed up too badly, should be fine, just need 6 new shims max, some might swap, not worth shopping about for them.
Offline philmcglass
  • Mine's a pint
  • Bike: Tiger XRX 2016
Re: Shimmy, Shimmy
« Reply #2 on: October 23, 2020, 01:01:10 PM »
You can use this to work out what shims you need.
Need to measure the shims in the engine and then work out the sizes needed to replace them.
http://www.agbuzz.com.au/valve/valve_intro.htm
Find the Line
Re: Shimmy, Shimmy
« Reply #3 on: October 23, 2020, 01:42:18 PM »
*Originally Posted by Arianta [+]
You clearances are not too dissimilar to those found in my recent 12k service. Measuring the exhaust clearances accurately is very difficult given the limited access and I re-measured mine many times before I was satisfied with the result. What I found was that I needed to be especially careful when comparing the measurements for Cyl 1 with those of Cyl 2 & 3 because the former can be measured much more easily from behind the cams rather than blindly in front of the cams for the other two cylinders. In the end, I decided that all the exhaust clearances were basically similar and therefore reduced all 6 x shims by 0.1 mm aiming to put the clearances at the top of the spec range. In fact, I would have been happy to reduce the shims by 0.15 mm knowing that the clearances would have reduced to 0.325 - 0.375 after a few thousand miles.
However, all this needs to be kept in perspective since a change in clearances of 0.1 mm does not represent much wear on the valve seats!
Re: Shimmy, Shimmy
« Reply #4 on: October 23, 2020, 02:45:26 PM »
... In fact, I would have been happy to reduce the shims by 0.15 mm knowing that the clearances would have reduced to 0.325 - 0.375 after a few thousand miles.
They don't tend to wear much after the initial 12K service IME, mine went from 12 to 45K without any noticeable wear
Re: Shimmy, Shimmy
« Reply #5 on: October 23, 2020, 03:10:46 PM »
A cylinder compression test will be the determinant.
If willing, many engines benefit nicely from expert valve face & valve seat head-work.
It's also much easier to adjust the clearance shims with the cylinder head on the workbench.
Offline Arianta
Re: Shimmy, Shimmy
« Reply #6 on: October 23, 2020, 03:29:59 PM »
My bike is just short of 24k so I'm in a bit of a quandry as to whether to rip the head off or trust in Triumph engineering. :114: :001:
Re: Shimmy, Shimmy
« Reply #7 on: October 23, 2020, 03:58:17 PM »
It will be fine, I've found them a lot tighter than that, almost zilch, so they'd never been done when paid for at dealers.
