Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: OEM chain  (Read 2413 times)
Re: OEM chain
« Reply #40 on: November 12, 2020, 09:43:32 AM »
No but I was measuring a new chain with no freeplay in it.
The problem I have with the DRC gauge is that it appears to be trying to measure the length of 11 x links + 1 roller thickness which theoretically should give a length of 184.6 mm for a 525 chain. However, 0% on the gauge appears to be a length of about 185.6 mm meaning that I get about 1 mm of freeplay on the gauge when I fit it to my chain!
Something's not right but I can't figure out what that is :084:
Offline D6864
  • Bike: White XC
Re: OEM chain
« Reply #41 on: November 12, 2020, 10:00:03 AM »
I use a similar gauge for pushbike chains (Lifeline Chain Wear Indicator) but it's a go/no-go gauge with 0.75% and 1% wear checks, perhaps the markings on the the DRC one indicate remaining chain life  :187:
Re: OEM chain
« Reply #42 on: November 12, 2020, 10:19:47 AM »
This gauge sounds like a silly toy.
For the newbies: First sign of a chain being on its way out is when it needs adjusting. A knackered chain has tight/loose spots so won't adjust to uniform slack. They never wear evenly, check at various positions on its length.
Offline dasf
  • Bike: 800 XCA 2017
Re: OEM chain
« Reply #43 on: November 12, 2020, 01:50:45 PM »
Still uses the original chain  and rear sprocket on my 800 XCA 2017.  Changed the front sprocket to 17 T at 3500 km and at the same time installed a Cobrra Nemo 2 chain luber.
The bike now shows 22 000 km and according to the DRC Chain Checker, wear is close to 0%.
Both front and rear sprocket looks like new.
Will be interesting to see how long they last.
Re: OEM chain
« Reply #44 on: November 12, 2020, 03:03:57 PM »
I've just done a test with the DRC chain checker on an old chain which I measured to have 0.4% stretch using a very accurate vernier calliper measurement.
The problem with the chain checker is that it is very difficult to judge where it contacts the roller to read off a measurement. On the old chain I tried, if I didn't know better, I could have convinced myself that the measurement was anywhere between 0.25% and 0.5%; in other words, between a half worn chain and a totally worn out chain. I therefore don't think the gauge is accurate enough and I for one will be sticking to using a vernier calliper!
