Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Kies heated jacket  (Read 788 times)
Offline Djairouks
Re: Kies heated jacket
« Reply #10 on: October 29, 2020, 05:58:06 PM »
There also is an argument to be made, when you use the battery a lot that a lithium battery might be safer if you see the voltage going down, because if your Lead battery goes too low it might die quite fast, as a lithium is fine until 30% discharge and then only loses cycles.
