Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Sticking front brake lever  (Read 496 times)
Offline julianhj
  • Bike: 2013 Tiger 800
« on: October 31, 2020, 09:24:41 PM »
I've noticed my front brake lever is not fully returning, meaning that on occasions the brake light switch is remaining activated. Is it a case of lubricating the bolt that retains the lever, and if so what is recommended? If not, what else might need doing? The brake is responsive, though the pads are getting close to the limit. The bike has recently been serviced and the fluid level is fine.
Offline romanrick
  • Bike: tiger 800xc
Re: Sticking front brake lever
« Reply #1 on: November 01, 2020, 10:40:57 AM »
Unscrew the pivot bolt and clean and grease it, if that does not work then perhaps a return to your servicing dealer.
Offline julianhj
« Reply #2 on: November 01, 2020, 10:43:02 AM »
Thanks, any particular type of grease?
Online Mav
  • Bike: 800 XRx
« Reply #3 on: November 01, 2020, 11:07:36 AM »
2017 XRx
« Reply #4 on: November 01, 2020, 11:22:31 AM »
*Originally Posted by romanrick [+]
Unscrew the pivot bolt and clean and grease it, ...
:0461: ... this is one of those minor tasks rarely thought about but I do mine every major service (12k) period. Grease and lubrication are good but adversely the lube also holds onto dirt and becomes claggy and thickens with time.
« Reply #5 on: November 01, 2020, 01:41:54 PM »
*Originally Posted by julianhj [+]
Hopefully, it's just the brake lever pivot that's stiff. However, it's the spring inside the master cylinder that pushes the lever back and, if the pivot isn't to blame, then it might need the master cylinder to be overhauled.
Online Paulhere
« Reply #6 on: November 01, 2020, 01:50:11 PM »
Bit late now, needs a strip down as said. Hopefully not the master cyl.
I give all the bikes pivots a wash out with WD40 then a squirt of aerosol grease, every few weeks. Give it some TLC it can be therapeutic.  :183:
Offline romanrick
  • Bike: tiger 800xc
« Reply #7 on: November 02, 2020, 09:04:02 PM »
General purpose grease is fine, better to take the  pivot pin out so grease goes where it's needed, and it only takes a few minutes. Do the clutch one as well, while you're at it.
