Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Strange clicking sound  (Read 959 times)
Offline Alan215
  • Bike: Triumph tiger
« on: November 04, 2020, 07:14:30 AM »
Hello just thought I would get an opinion on this clicking I thought it was the chain loose so adjusted it to the correct play but when I pull off it does it for a short time (sounds like a playing card in bike spokes) not sure if it does it when I pull the clutch in as like I said only does it for a short time though it might b chain taking up slack but not sure now any ideas
Offline Aussie Tiger
  • Bike: 900 Rally Pro
Re: Strange clicking sound
« Reply #1 on: November 04, 2020, 07:29:30 AM »
Have you checked that the rubber running strip is intact?
« Reply #2 on: November 04, 2020, 08:53:14 AM »
^^^ or crud in front sprocket. Loose/tight spots in chain.
« Reply #3 on: November 04, 2020, 08:54:08 AM »
Could possibly be a loose front sprocket. There is a locking plate there so it won't come off but it may not be threaded tightly on the shaft. Or it could also be that the chain is worn and so the links will be noisy on the front sprocket.
« Reply #4 on: November 04, 2020, 09:00:56 AM »
Have you tried putting the bike on its centre stand to allow you to run the engine in gear to make it easier to stand next to the bike to better hear where the clicking is coming from?
Offline Alan215
« Reply #5 on: November 04, 2020, 11:54:01 AM »
Hello all Ill take a look the weekend as first chance to look Ill update when done
Offline Alan215
« Reply #6 on: November 06, 2020, 04:49:09 PM »
Hello just an update so went out brought a torque wrench a 36mm socket and had a look to see if the front sprocket nut was loose took sprocket cover off and sprocket nut looked ok not loose folded back washer undone nut retightened nut folded washed twice then took for ride no rattle now alls good but need to have two up with wifie on as thats when I was noticing most fingers crossed
Offline SOHUTAA
  • Bike: T800 Xcx 2016
« Reply #7 on: November 06, 2020, 10:37:33 PM »
 :028:
Offline Thripster
« Reply #8 on: November 07, 2020, 08:10:22 AM »
If that were my situation, I'd be checking that she isn't knitting you a new hat........(wot may be causing the clicking)
Offline Alan215
« Reply #9 on: November 07, 2020, 09:40:37 AM »
I doubt that shes to busy hanging on 😀
