Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Handlebar phone carrier  (Read 710 times)
Offline Ace23
« on: November 07, 2020, 11:05:52 PM »
Hi, Can you guys let me know your opinions for a good handlebar phone holder  there's loads on fleabay but I want something that I won't lose my phone on while out riding..
Offline Dublin Rider
Re: Handlebar phone carrier
« Reply #1 on: November 08, 2020, 12:21:43 AM »
I'm gonna order a Ultimate Addonns case/mount - options to be mounted on the bars, mirror stem, top mount etc.
https://ultimateaddons.com/collections/universal-motorcycle
 Waterproof, has an opening for charging on the go so can easy power via the port at the ignition.
SP connect and Quad Lock are other decent mounts.
« Reply #2 on: November 08, 2020, 12:43:26 AM »
Quad lock with a Ram Mount is a good combination
Online matt748
  • Bike: 800 XRX
« Reply #3 on: November 08, 2020, 07:11:05 AM »
Ive been using Ultimate Addons for 2 years, via a Ram mount. Superb.
Offline PapaTom
« Reply #4 on: November 08, 2020, 08:04:36 AM »
Don't forget about the potential risk of vibration damage to a mobile phone mounted this way.
Apparently it particularly affects iPhone cameras.
I believe quadlock sell a damping kit that fits between the mount and the phone case.
Just a thought.
Offline Ace23
« Reply #5 on: November 08, 2020, 10:29:54 AM »
thanks guys I'll check them out it is for mounting my phone I'm also going to run a USB lead to it to charge on the go in case I use the sat nav in the phone.
« Reply #6 on: November 08, 2020, 11:06:39 PM »
Quad Lock also have wireless charging adaptor instead of a USB cable if your phone is equipped. I don't have one myself.
Offline Petstep
« Reply #7 on: November 09, 2020, 07:33:58 AM »
I've used various cheap versions over the years, but glad I forked out a bit more for the kappa holder (budget version of the Givi). Well made and with a substantial quick release clip to fix to the bike. Securing it the the bars was a fiddle, but got there in the end, and you only have to fit it once!.
Offline Mountie
« Reply #8 on: November 09, 2020, 02:17:11 PM »
Ultimate Addons case with a RAM mount is the way to go if you want something waterproof
https://ultimateaddons.com/collections/motorcycle-cases
If you use TEAPOTONE10 you should be able to 10% off.
Tiger 800 XRT & Bonneville T100
