Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: GT Pro Shift Assist  (Read 3295 times)
Offline Jonjak
GT Pro Shift Assist
« on: November 18, 2020, 06:39:43 PM »
I think Im losing touch of reality. I would like a general opinion of what a good quick shifter, or Triumph shift assist should offer. Im just over a 1k miles in, and Im positive that it was working better before my 1st service. All the way home, it worked around 30%. Now its closer to 90% but going down needs a lot of effort and certainly doesnt impress. Do I complain or accept ?
Online Alan B
  • Bike: RE Interceptor
Re: GT Pro Shift Assist
« Reply #1 on: November 18, 2020, 08:00:58 PM »
I don't use it for 1st to 2nd, or 2nd to 1st, but otherwise use it all the time when accelerating or braking and it works 100%.  Don't use it when changing gear at steady speed, or when revs to low.  Think you may have a problem.
Offline Colinhitch
  • Bike: 900 Rally Pro
« Reply #2 on: November 19, 2020, 08:31:13 AM »
Done 10500 miles, works fine.
Offline Rickscotland
  • Bike: 900 GT
« Reply #3 on: November 19, 2020, 12:18:50 PM »
Just a thought....double check that the shift assist wasnt switched off during the service. You can enable/disable it in the settings menu. 🧐🧐🧐
Offline Jonjak
« Reply #4 on: November 22, 2020, 10:59:59 PM »
Assist was not turned off as it still works. Checked chain and its ok. Down shifts are hit or miss. I will try and get booked in asap. Thanks
Offline Aussie Tiger
« Reply #5 on: November 23, 2020, 12:20:34 AM »
Not saying youre not, but make sure youre not resting you foot on the shift lever at all. If you are then the shift assist wont work at all or not properly. Also, are you sure its enabled? What seems like working sometimes, might actually be clutchless changes but without the finesse.
In any case, yours is not right and you should not just accept it the way it is.
Offline hartsideman
« Reply #6 on: December 04, 2020, 12:15:27 AM »
loads of issues reported on quickshifters , i speak from experience , they get water ingress and then pack up , never get a hose pipe or god forbid a pressure washer within a few inches of these or you are in for a world of pain .. theres a facebook forum .... Triumph Tiger 900 and Tiger Sport 850 owners group .... and its a daily post on there , also how useless the top "tank guards are " ...
It's Here and it's Freaking Awesome "nuff Said"
I've learned sooo much from my mistakes.. I'm thinking of making some more ;-)
Offline Oldbadgedr
  • Bike: Tiger 900 rally
« Reply #7 on: December 12, 2020, 07:12:07 PM »
Mine failed last week on my Rally Pro, after an all year biker treatment. I think too much water, but on a bike should that really be a problem ? These are off road machines ffs. Took it in to the dealer, new QS under warranty, still not fixed the issue, now need a new clutch switch to find out if that resolves the issue. After needing a full rebuild of my 2018 street triple rs, I am rapidly loosing my confidence in Triumph as a brand. Shame really as the Rally Pro is an absolute dream to ride in all conditions.
Offline Jonjak
« Reply #8 on: December 21, 2020, 09:14:23 PM »
Murphys Law. Recently took bike into dealer to get the quick shifter looked at. Gears were near perfect all the way there, and during the test ride, so no action needed. Halfway home and they packed up completely. Will look at returning in the new year now.
Offline rainbow-walker
  • Bike: Triumph Tiger
« Reply #9 on: December 22, 2020, 04:57:00 PM »
Had mine replaced at the 600 mile service, been ok since and now on 5K.
RBW.
